Scalos 40.33 released
  • juergen
    Posts: 42 from 2005/2/2
  • »23.04.05 - 16:14
  • juergen
  • »27.04.05 - 22:22
    Posts: 1931 from 2003/10/19
    Everything seems to work for me here as well. no trouble with any
    background image at all.
  • »27.04.05 - 22:28
  • Targhan
    Posts: 2833 from 2003/2/8
    Have you ever check the icon attributes? With Scalos and WB3.9 you can select the start method for the program (WB/shell/ARexx). AFAIK, Ambient doesn't support that.
    If you set the startup method to "Workbench", dnetc should work as before.
    That's something worth remembering too, because it could affect other programs as well. I fully remember that issue from the old NetConnect start-bar too (having to select wb shell arexx).
    on a side note, would it be a good idea for someone with a good set of scalos.prefs to upload their *working* prefs to the forum here?
    :idea:Targhan
  • »27.04.05 - 23:57
    Sergio
    Posts: 90 from 2005/2/16
    Scalos works like a charm on my MOS 1.4.2 Peg1, it has become my main desktop.
    Getting it to work has been easy, except that I had to ask someone for the ghost mcc, the one you can't find for downloading anywhere.
    The prefs program can be a bit confusing but I found my way quickly (it's not the first time I use Scalos, I even paid for it once) - I still have to find out how to disable the splashscreen and other minor things.
    And yes, the Scalos icon here looks like $hit! :-D
    Serge
    [ Edited by Sergio on 2005/4/28 12:54 ]
    [ Edited by Sergio on 2005/4/28 12:58 ]
  • »28.04.05 - 12:40
  • pod
    pod
    Posts: 8 from 2005/1/20
    Yes, I checked them. It was correctly configured for "Workbench". I tried the two other options anyway - with arexx nothing happened at all, shell was the same as Workbench!? Is anyone here using this Scalos Version together with dnetc without problems? Maybe I should try a newer dnetc Version...
  • »28.04.05 - 13:50
  • juergen
  • »28.04.05 - 14:16
    Sergio
    ghost mcc ?? Which one are you talking about?
    pophotkey.mcc - I couldn't find it neitherr in the archive nor in my MOS Install. I managed to get it anyhow. BTW many thanks to all Scalos team for porting my favourite 68k desktop to PPC.
    Serge
  • »28.04.05 - 19:58
  • juergen
  • »28.04.05 - 21:00
    Sergio
    In the readme.txt that is part of the installation package,
    Oops, I should learn to RTFM. I just assumed it would be referenced on aminet.
    Serge
  • »29.04.05 - 09:32
    Senex
    Posts: 498 from 2003/2/17
    They are also not visible. The only backdrop i can see is that on the status bar at the bottom of windows
    Problem has simply been that the installer didn't copy all files into the Theme directory - doing it manually solves it.
  • »03.05.05 - 19:19
