MorphUp Package Manager 1st public beta
    naTmeg
    Posts: 135 from 2004/2/8
    Introduction
    To use applications on AmigaOS/MorphOS users have very often to go to several different websites, download, extract and install the files manualy. This is time consuming and can lead to a messed up system.
    MorphUp is a package manager to solve this problem. It is implemented in two parts, the generator and the client. The generator is used to generate the packages, which can be hosted on any http-server and the client is used to fetch them and handle them, on the target machine...
    Features
    Overall features over both applications:
    Packagesystem
    - Packages can be grouped by type.
    - Theoreticaly unlimited packages per group and unlimited dirs/files per package.
    - Can handle file size up to (the DOS limitation of) 2 GB.
    - Extraction of files without the need of unpacking the whole package.
    - Real directory structures in packages.
    - 3 different package types.
    - Full packages, to transfer a huge amount of files at once.
    - Single packages, to safe bandwitch if only a few files need to transfered.
    - Link packages, to refer to other archives.
    - Full packages automaticly split into parts if they grow too larger while generation.
    - Dynamic block compression based on zlib.
    - Differentiation between system and application files.
    - Tag-based saving to easy add things later.
    GUIs
    - Multithreaded MUI applications, can handle multiple indexes at same time.
    - Many editing functions like: add, remove, makedir, add recursive...
    - Cut&Paste edit mode, even over different packages.
    - Dynamic context menus.
    - Controlable through application menus, contextmenus, keyboard.
    Other
    - Configurable datatype system.
    - Configurable data classes system, to avoid hardcoded paths.
    - Configurable package classes system.
    - Uses XAD system to support many types of archives in link packages.
    - Packages can have a picture, either JPG or PNG/PNG + alpha
    - Multilevel log system with possibility to log to disk.
    - Small memory usage.
    Grab it HERE
  • »22.12.05 - 12:03
    Posts: 655 from 2004/4/15
    Great, looks very good.
    But now i am missing some server ;)
  • »22.12.05 - 13:54
    naTmeg
    You can test with this one:
    http://member.ycn.com/~hausrup/morphup/morphos/index_mos.pmi
  • »22.12.05 - 14:31
  • Leo
    Leo
    Posts: 428 from 2003/8/18
    @naTmeg: it seems to work *very well*...
    Some questions though:
    .With the server, when adding files to a package, is there a way to add a complete directory and its subdirectories ?
    => Pressing "all files" on the requester only selects and adds files found in the selected directory.
    If not, that's a suggestion :)
    .Where are the package description & picture displayed in the Client ? I created a package, put in on a server and run the client: I was able to see its contents, name, and download it but its description and picture didn't appear anywhere...
    .Is there a way to execute a script at the end of the installation of a package ?
    If not that's another suggestion :)
    => We could for example imagine a script that adds the newly installed application on the desktop, or on a panel if the user wants to... The application could also be launched after the installation is finished. And what if an assign is needed ?
    Keep up the great work !
    Leo.
  • »22.12.05 - 14:57
    naTmeg
    @leo:
    The answers for your questions are in the context menus. They built dynamic for every entry/type selected :)
  • »22.12.05 - 15:16
    pixie
    Posts: 148 from 2003/9/5
    Congratulations to all involved! :-)
    [ Edited by pixie on 2005/12/23 0:37 ]
    pixie - writing from a paradise called Portugal
  • »22.12.05 - 16:20
    Posts: 1932 from 2003/10/19
    I've been waiting for this one. Can it be used in its current state to look at my system and then go look for what I need to update? Cant wait to see it it action.
  • »23.12.05 - 01:17
    Yomgui
    Posts: 348 from 2004/8/31
    Congratulation!
    I've not tested yet, but I've a question: does it use MD5 to check files version or/and version tag ($VERS)? Because not all files have a version tag.
    And now... next project!
  • »23.12.05 - 06:55
    naTmeg
    @Yomgui:
    it uses MD5 for checking files valid, and it uses $VER, if found :)
  • »23.12.05 - 07:43
    BatteMan
    Posts: 294 from 2003/2/24
    naTmeg :  Great Job ! Really !
    But, one thing is missing : a description of the package to know what we're going to install.
    /me is going to put some money on the bounty.
  • »23.12.05 - 08:10
    naTmeg
    @BatteMan:
    You can see the descrition if you enable the "Info-Group" in the client. Press RMB in the left list and select "Show info group" from context menu. Cycle the "Mode" from "Picture" to "Info". Now you should see a short/long description... :)
  • »23.12.05 - 09:04
    roschmyr
    Posts: 211 from 2003/2/20
    and another package to test
    Thanks Krashan
    http://teleinfo.pb.bialystok.pl/~krashan/software/tte/files/ttengine.pmi
    [ Edited by roschmyr on 2005/12/25 18:14 ]
  • »25.12.05 - 08:04
    Krashan
    Posts: 1107 from 2003/6/11
    I've mailed naTmeg already about agreeing on MIME type for MorphUp packages (my proposal is 'application/x-morphup'), so we can arrange browsers (after adding some functionality to MUClient) in such a way that click on *.pmi link will start MUClient automatically and add the new source. Of course there is some problem, you have to be an administrator of a web server to effectively add a new MIME type (which is the case for me :-) ).
  • »25.12.05 - 08:55
    naTmeg
    How to configure IBrowse to directly load a .pmi into muCl:
    1. Get latest client via MU
    1. Open IB/Settings/Ext.Viewer
    2. Add a new MIME type:
    - Type: application/x-morphup
    - Ending: pmi
    - Action: External Viewer
    - Viewer: muCl
    - Args: ADDSERVER %r
    ...before pressing a .pmi-link make sure muCl is NOT running, because only one instance is allowed. If you try to add a index that is already in the listtree you will get the error-msg "This server/index already exists".
  • »25.12.05 - 11:32
    guruman
    Posts: 462 from 2003/7/21
    First of all, very nice work! It seems to be already usable and useful, therefore I made a (small) well deserved donation to the bounty! - the bounty is still open for donors - hint! hint! ;-)
    I'd have a couple of suggestions:
    - I think the client should report an up-to-date packet if the only diffs are located in the icons: for instance, you get an orange sign if you change a tooltype, and this would happen if you changed the icon with one taken from the Contrib/ dir often found in the archives. Of course you can easily check everything from MuCl, but I'd like the check to report the green signs in these cases, so that I don't have to further control.
    - is it possible to have the possibility to create a packet and a description, save it in some kind of Packet Manager Description file, and then create/update an index (.pmi) just adding new "descriptions" (say, .pmd or anything else)? This would be useful for sites like MorphZone or morphos-news, and possibly AmiNet, if it was easy it wouldn't give much work to the moderators (even better if it was semi-automatic), and with just a couple of Index we would check the majority of software. Moreover, not all the authors would need some webspace of their own to support MorphUp. Yet, by adding the "description" themselves, there wouldn't be a duplication which would be confusing: all the sites would use that one. Moreover MuCl might cross check packages on different sources to get the latest, even if sometimes not all the sites have an updated one.
    - this is more a question: if the user has a newer system file than the one that's going to be installed, is copy skipped by default?
    - is it possible to create some cross-dependencies between packets? For instance, YAM needs some MUI classes not included in the archive: I think they should be "linked" (and downloaded with YAM itself anytime they are needed and not present/obsolete).
    - I agree with the suggestion to let some scripting be executed as part of the installation process (even just simple DOS scripts). This should be carefully planned though, in order to prevent malicious exploits (although any unverified script is potentially dangerous).
    - I would add some subclasses to the Package Classes: I have subdirs in Graphics and Games, for instance... It should be possible to discriminate between Picture Viewers/Image Processors/Paint Programs and 3D, or between SDL ports/Arcade/FPS, or between Browsers/P2P/Mail/Instant Messaging. In order not to give too much hassle to the user, uspecified subclasses should "backfall" to their principal class, so, if you have a single level tree you wouldn't need to specify anything more than now. In my case, a check for ShowGirls would fail as it stands now...
    That's all, for now ;-) . I'd like to hear also Dr.Morbius and tokai opinion about this program, since they wrote a good article about Installation Procedures...
    Kind regards,
    Andrea
  • »25.12.05 - 16:03
  • pOS
    pOS
    Posts: 220 from 2003/11/14
  • »25.12.05 - 19:52
    naTmeg
    @pOS:
    >How can I define a local directory to install the packages from instead from an internet location ? Do I have to us an URL like file://Work:Downloads/ ?
    What do you mean by this? If you want to handle .pmi files from disk, use "Add Index" button. This loads local (on your machine) indexes ie. for testing before upload.
    >Is it possible to install packages also if the index file doesn't exist (any more) ß
    No, thats not possible so far, but should be a option in the future.
    >Can I extract package files manually, too ?
    Why you should do that? I see no reason in doing this.
    @guruman:
    >I think the client should report an up-to-date packet if the only diffs are located in the icons...
    Yes, in the future there should be an alternate state of the icons, showing the install-state, not only the file-state like now.
    >Is it possible to have the possibility to create a packet and a description...
    Thats a good point, but sounds a bit complicated to implement in the current state. Such complexity was not planned in the beginning, was not in the bounty requirements.
    >I agree with the suggestion to let some scripting be executed as part of the installation process...
    This option is discussed in many ways already and i agree with you. Could be implemented after 1.0...
    >I would add some subclasses to the Package Classes...
    Ok, but then one _must_ give a path for such a subclass. There is no difference to "Install at..." then.
    Thanks for your feedback :)
  • »25.12.05 - 21:35
  • pOS
    pOS
    naTmeg wrote:
    @pOS:
    That was my question. Ok, will give it a try.
    Some background:
    1.As I only have a 58K modem connection at home, I often use you another computer to downlaod archives/packages than the one they are to be installed.
    2.I often don't want to install immediately after download.
    3.Sometimes I like to have a look at the contents of an archive *before* I install it, especially if some system components might be changed.
    Now imagine, MorphUp becomes such a success that some programms are not offered as .lha archive any more but only as MorphUp package. Then it would be nice to still have the ability (at least sometimes) to extract it manually and check its contents.
    One more question/suggestion.
    If I understood right, links are meant to create dependencies between packages ? If so it would be nice to make those dependencies a bit more flexible.
    I'll give you an example:
    You have a package for MyNewMP3Player. The programm requires mpega.library. There are two implementations of this library, the original one and the one based on libmad. So MyNewMP3Player.package should have a dependency that ITHER mpegorig.package OR mpeglibmad.package must be installed before. And of course, if someone already has installed his favourite implementation it shouldn't automatically be overwritten by another one.
  • »26.12.05 - 16:52
    naTmeg
    @pOS:
    >Sometimes I like to have a look at the contents of an archive *before* I install it...
    Well, with the client you see all contents and descriptions even before downloading the package.
    No. Link-packakages are use to refer to antoher archives, ie. files on aminet. At generation, you must give the URL to the archive you want to refer to. Then this archive is
    temporary downloaded by the client and converted to a index file. So, if you install such a package it grabs from aminet instead from ie. your HP. People can use this if they have no hostspace. Its just a link to another archive of any type, like lha, lzx, zip...
  • »26.12.05 - 19:32
    Posts: 72 from 2003/2/24
    guruman wrote:
    "- I would add some subclasses to the Package Classes: I have subdirs in Graphics and Games, for instance... It should be possible to discriminate between Picture Viewers/Image Processors/Paint Programs and 3D, or between SDL ports/Arcade/FPS, or between Browsers/P2P/Mail/Instant Messaging."
    I've made up an alternative to the old Aminet dir structure (with help from Felix Schwarz and others), that is much more user-friendly and up-to-date. Feel free to use and abuse it! :) (And it could make a good category standard for the Package Manager- mail me if you want a better formatted version):
    Amiga/AROS/MorphOS App Categories V1.3 (28/12/05)
    Audio
    Audio Utilities
    Sample Editing/Manipulation
    Midi/Mod Sequencing Editors
    Miscellaneous Audio Programs
    MP3 Grabbers
    MP3/Midi/Mod/Internet Radio Players
    Business
    Accounting Programs
    Application Service Provider Programs (ASP)
    Calendar Programs
    Database/Data Mining Programs
    E-Commerce Software
    Enterprise Resource Planning Programs (ERP)
    Miscellaneous Business Programs
    Personal Information Managers
    Communications
    Communication Utilities
    E-Mailers
    Fax Programs
    IRC/FTP/SSH/Version Control Programs
    Instant Messaging Programs/Internet Phone/Video Conferencing Software/Webcams
    Miscellaneous Communication Programs
    Peer To Peer File Sharing Programs
    IP Stacks/Firewalls
    Web Browsers
    Data Storage/File Management
    CD/DVD Burning Programs/Utilities
    File Management Programs
    Miscellaneous Data Storage Programs
    PDA Utilities
    Storage Utilities:
    Archivers/Dearchivers
    Backup Utilities
    Encryption Programs
    Optimiser/Defrag Utilities
    Miscellaneous
    Monitors
    Demos
    Intros
    Magazine
    Miscellaneous Demos
    Demo Parties
    Slideshows
    Sound
    Development Tools
    Languages:
    Arexx
    Compilers/Interpreters
    Source
    Utilities
    Assembler
    Assemblers/Disassemblers
    Source
    68k
    PPC
    x86
    Utilities
    Basic
    Source
    Utilities
    C/C++/Objective-C/C#
    Compilers
    Source
    Utilities
    E
    Source
    Utilities
    Fortran
    Source
    Utilities
    Java
    Source
    Utilities
    JavaScript
    Source
    Utilities
    LISP
    Source
    Utilities
    Pascal
    Source
    Utilities
    PHP
    Source
    Utilities
    Python
    Source
    Utilities
    Ruby
    Source
    Utilities
    Development Libraries
    Development Utilities
    Editors/Integrated Development Environments
    GUI Builders
    Miscellaneous Development Programs
    Games
    Beat-em-up Games
    Board Games
    Card Games
    Emulators (Arcade, Sega, Nintendo etc)
    First-Person Shooters
    Game Cheats and Walk-Throughs
    Game Utilities
    Kids Games
    Miscellaneous Games
    Movement/Webcam Games
    Platform Games
    Puzzle Games
    Quiz Games
    Role Playing Games (RPGs)
    Rhythm/Music Games
    Singing Games
    Shoot-em-up Games
    Sports Games
    Strategy Games
    Target (Shooting) Games
    Tetris/Block/Bubble Games
    Text Based Adventure Games
    War/Vehicle/Space Simulators
    Graphics/Video Programs
    3D Rendering/Editor Programs
    Animation/Video/DVD Players
    Backdrops
    CAD Programs
    Digital Camera/Video Recorder Utilities
    DVD Authoring Programs
    Graphic Utilities
    Paint Programs/2D Animators/Image Processors
    Personal Video Recorders/Streaming Video Players
    Fractal Programs
    Miscellaneous Graphic/Video Programs
    Multimedia Presentation Programs
    Picture Viewer/Database Programs
    Scanning Programs
    Screensavers
    Scalable Vector Graphics Programs
    TV Tuners
    Video Editing Programs
    Video Titling Software
    Video Utilities
    Scientific
    Atlases, Star Charting Programs
    Geographic Information Software
    Mathematics Programs
    Miscellaneous Scientific Programs
    System
    Classes
    Datatypes
    Drivers:
    Audio Drivers
    Bus Drivers
    Camera/Video Camera/WebCam Drivers
    CD/DVD Drivers
    Controller Drivers
    Data Storage Drivers
    Drawing Tablet Drivers
    Filesystem Drivers
    Firewire Drivers
    Graphics Drivers
    Keyboard Drivers
    Miscellaneous Drivers
    Modem Drivers
    Monitor Drivers
    Mouse Drivers
    Network Drivers
    PIPE Drivers
    Printer Drivers
    Scanner Drivers
    Serial/Parallel Drivers
    Tape Drive Drivers
    Touchscreen Drivers
    TV Tuner Drivers
    Wireless Drivers
    USB Drivers
    Fonts
    Libraries
    Handlers (L: dir)
    Keyboard Maps (Keymaps)
    Miscellaneous System Programs
    MUI Window/Gadget environment
    Reaction Window/Gadget environment
    Text/Word Processing, Desktop Publishing, Office programs
    Font Utilities
    Miscellaneous Text Programs
    Office Programs/Word Processors/Desktop Publishers/HTML Editors
    Print Programs
    Spreadsheet Programs
    Spell Checkers/Thesauruses
    Text Utilities
    Text Viewers/Editors
    Utilities
    Ambient Utilities
    Backdrops
    Boot Utilities
    Calculators
    Clocks
    Miscellaneous Utilities
    Operating System/Hardware Emulators
    Shell (CLI) Programs
    System Monitors/Utilities
    Virus/Spyware Checkers
    Workbench Utilities
    [ Edited by Ants on 2005/12/28 23:03 ]
    - Ants
  • »28.12.05 - 01:52
    naTmeg
    @Ants:
    Thanks to all involved for that nice collection :)
  • »30.12.05 - 02:10
