Posts: 12085 from 2003/5/22
> NAP is used in MorphOS since the Mac mini release
I know. My question was only referring to DFS support. My bad, as I wasn't clear enough on this.
> DFS2 support was added months ago, before Alchimie, so perhaps
> something got lost in translation there.
Fab's slides contain the following statement in orange colour, i.e. planned for only after MorphOS 3.0:
Gestion contrôlée de l'énergie de différents composants en fonction des capteurs et préférences utilisateur (vitesse du processeur [...])"
...which Google translates into:
Controlled management of the energy of different components depending on the sensors and user preferences (processor speed [...])"
So if DFS support had already been implemented in MorphOS before Alchimie, then what's the feature mentioned in the slide for MorphOS after 3.0 referring to? Or is it just that Fab missed to colour it green?
