Posts: 2730 from 2003/2/24
Quote:judas wrote:
I guess you did the right thing.
Peg2's are maximum attractive, especially because of the OS4.1 available now.
(Which I also bought
Well, what the Peg2 lacks in raw CPU power, it gains in expandability and configuration options. So it boils down to what's most important to you and your daily MorphOS use - flexibility or CPU power.
Remembering how long it took for MorphOS to support Gigabit on the PEG2
Actually, the Peg2 Gigabit support in MorphOS didn't take particularly long at all. However, it was only released with MorphOS 2 years later...
I would recommend to buy a machine which can use the SW now, and not in some distant future.
I think that's a good recommendation!
MorphOS is Amiga
done right!
MorphOS NG will be AROS
done right!
