Guide FLASH ATI 9250/9200 AGP, MorphOS (PowerMac AGP)
    Divinity
    Posts: 517 from 2009/9/8
    Here the guide to FLASH ATI 9250/9200 AGP for O.S. MorphOS / Linux / OSX / OS9
    http://amiga.ikirsector.it/forum/viewtopic.php?f=40&t=14669&p=171419#p171419
    [ Edited by Divinity on 2010/10/20 20:20 ]
    [ Edited by Divinity on 2010/10/20 20:21 ]
  • »20.10.10 - 16:03
    kickstart
    Posts: 227 from 2009/4/28
    Nice guide, but some links dont work for me... any english version?
  • »20.10.10 - 20:56
    Divinity
    thanks, here the links/url are ok
    If someone has time to translate it in english sure  :-)
    [ Edited by Divinity on 2010/10/21 10:33 ]
  • »21.10.10 - 06:33
    Divinity
    @all
    guide in English by @Jambalah  :-)
    http://jambalah.altervista.org/Guide/ATIFlash.lha
  • »04.11.10 - 16:39
    English translation link does not work for me.
  • »04.11.10 - 23:29
    Jambalah
    Posts: 820 from 2008/3/30
    @Amigadave:
    Link brings you to a Altervista page in wich there is another link for download. Sorry, it's
    a strange behaviour of this website. But I guess Papiosaur solved with his link  :-)
    @Papiosaur:
    Thanks!! :-D
    I thought for a french version but MagicalInk hates the accents: every time you press
    an accented vocal, program crash and you can only exit ...  :-?
    Pegasos II 1 ghz
    Powermac G5 dual 2.0 ghz
    Powerbook G4 1.67 ghz 17
  • »05.11.10 - 04:14
    Posts: 1086 from 2003/3/24
    I have one question. What i have to install on the Floppy or better the USB Key?
    Freedos???
  • »05.11.10 - 21:10
    Divinity
    Freedos???
    If you have a floppy drive (internal or external USB) use it, if not you use a media DOS bootable (es. cdrom, or USB key ...etc...)
    [ Edited by Divinity on 2010/11/6 2:02 ]
  • »05.11.10 - 22:01
    I've did it!!!!
    After 4 hours of getting the right PC and the right floppy drive and the right floppy and get it bootable on the Amiga Meeting in Bad Bramstedt. No Windows allowed. I did the trick.
    I flashed a ATI Sapphire 9250 128Bit 256MB i had to solder the resistor like described in the great Guide.
    Now i will try a HIS Radeon 9200.
    And when i m done with that i will OC my CPU.
  • »06.11.10 - 12:24
    @ThePlayer,
    Congrats! I would think that it is very hard to find any PC's that have AGP video slots anymore. Most have probably been discarded in the trash. I have never owned one, or even seen one that I can remember, so if I ever decide to try to flash a graphics card to use in a Mac, I will most likely need to try the method of doing it in my G4 PowerMac itself, instead of finding a PC with the needed AGP slot in it.
  • »06.11.10 - 18:00
    Now i have flashed the HIS Radeon 9200 but i have to figure out which resistor i have to move. The card has a slightly different design.
  • »06.11.10 - 19:09
    Dragster
    Posts: 99 from 2005/11/6
    Hi there.
    Several months ago I bought a Radeon 9250 128bit bus 256 MB ram gfx card from ebay (AGP) and I haven't been able to make it work on my Pegasos... I'm not sure if the issue has to do with the voltage that doesn't match or if I?have to flash it like described in this thread/guide...
    So, the question is, could this make it work on my PegII??Thanks for any help.
    Cheers,
    Dragster
    [ Edited by Dragster on 2010/11/7 9:58 ]
  • »07.11.10 - 13:57
    Posts: 12539 from 2003/5/22
    No, Pegasos can't use cards with PPC Mac ROM.
  • »07.11.10 - 14:34
    Dragster
    OK, thanks!
    Any suggestions to make it wortk?
    Cheers
    [ Edited by Dragster on 2010/11/7 12:39 ]
  • »07.11.10 - 16:38
    Golem
    Posts: 766 from 2003/2/28
    @Dragster
    Verify the card actually works in another system?
  • »07.11.10 - 16:49
    Dragster
    It does in a PC...
  • »07.11.10 - 17:52
    Divinity
    It does in a PC...
    Is It 1.1 or 1.2 the Smart Firmware in the Pegasos2 ?.
    I had 1.1 and the same problem, solved flashing the Smart Firmware at 1.2 (in this case, contact Bplan to have the right file).
  • »07.11.10 - 18:31
    Dragster
    Divinity wrote:
    It does in a PC...
    Thanks,
    It's firmware 1.2 (revision 2b5 board)...
  • »07.11.10 - 18:56
