ARexx and 2.5
    gdanko
    Posts: 28 from 2010/6/8
    Is it installed by default? How do I use it? On my linux box I installed regina-rexx. How do I get to using it on MorphOS?
  • »17.06.10 - 01:06
    Papiosaur
    Posts: 2615 from 2003/4/10
    To activate Arexx in MorphOS
    You must rename file sys:morphos/libs/rexxsyslib.library to rexxsyslib.library_old for desactivate it then copy file rexxsyslib.library from AmigaOS 3.x to sys:libs/
    it is in the FAQ i think ;-)
  • »17.06.10 - 05:08
    Piru
    Posts: 624 from 2003/2/24
    And here's how you can find rexxsyslib.library:
    http://aminet.net/search?content=rexxsyslib.library&sort=bytes
  • »17.06.10 - 09:26
    gdanko
    Once the lib is installed what's the rexx interpreter's filename?
  • »17.06.10 - 10:21
    Golem
    Posts: 766 from 2003/2/28
    You can use RX to run scripts/commands/etc. RexxMast is started by startup-sequence.
  • »17.06.10 - 10:26
    gdanko
    Forgive me as I am coming from a Linux background. It's been a long time since I've used my Amiga. On Linux I install regina-rexx via apt-get and I can execute:
    regina script.rexx from the CLI
    Can this be done from the MorphOS shell? Can I open a shell and type:
    RX script.rexx?
  • »17.06.10 - 10:47
    Posts: 2220 from 2003/2/24
    Yes, "rx script.rexx" works from shell and if your script has "s" protection bit set, then it works just by "script.rexx".
    MorphOS also has couple of handy shell commands for arexx. PortList gives you all available port names and with RXCmd you can send arexx commands to them without using actual arexx script. It can be useful with shell scripts or hotkeys etc.
  • »17.06.10 - 11:23
    gdanko
    Excellent, thanks jPV. I can't wait to get moving on all the things I want to do with Morph. :) Kudos to the dev team for a truly amazing product.
  • »17.06.10 - 11:38
    osco
    Posts: 680 from 2009/10/20
    To the angels
    Still in tears of joy....
    I've lost my family but coding like a saint.
     :-D
  • »17.06.10 - 16:27
    Matt_H
    Posts: 30 from 2009/2/21
    Out of curiosity, why does MOSSYS:Libs/rexxsyslib.library even exist if it doesn't do anything? Or does it do something?
  • »17.06.10 - 23:29
  • Fab
    Fab
    Posts: 1331 from 2003/6/16
    It does something. It implements the needed functions required to make rexx messages work, which are required by many applications (in fact, almost all, since mui uses it). It "just" lacks the interpreter.
  • »18.06.10 - 00:04
