Streaming video with OWB?
    osco
    Posts: 680 from 2009/10/20
    I have a site that offers streaming video ..horse racing. It has a media check an expects Microsoft Media Player or Flip4mac for a Safari Browser. OWB can access the site, log in, and use most of the site. What to do? 8-)  8-)  8-)  8-)
    MPlayer now works with OWB and getVideo
    [ Edited by osco on 2009/12/20 20:27 ]
    TY ALL
    [ Edited by osco on 2009/12/20 20:28 ]
  • »19.12.09 - 14:06
    Golem
    Posts: 766 from 2003/2/28
    Find the stream url and open it with mplayer.
  • »19.12.09 - 14:27
    osco
    :-x
    Link
    opens a cache then dies..no video :-D
    [ Edited by osco on 2009/12/19 12:00 ]
    trying yahoo video
  • »19.12.09 - 14:43
    Golem
    Yes, that is not a stream.
  • »19.12.09 - 15:08
    osco
    Would like any url to see if OWB and Mplayer will work?
  • »19.12.09 - 15:35
    xyphoid
    Posts: 870 from 2008/7/11
    try any youtube video, or google video don't run anything else while doing this though.
    here's one
    Busted
    [ Edited by xyphoid on 2009/12/19 13:50 ]
  • »19.12.09 - 16:38
    osco
    http://www.tvg.com/Authenticated/livevideo/MediaPlayerTopFrame.aspx?ReadyToPlay=1&Replay=0&Speed=SUPER&Size=SMALL&TrackAbbr=TAM&TrackName=Tampa%20Bay%20Downs
    This is the url! Can any try?
    I pasted the url in Mplayer but it hung?
    [ Edited by osco on 2009/12/19 15:05 ]
  • »19.12.09 - 18:02
    Posts: 1073 from 2004/9/23
    I configured OWB to launch MPlayer for any pls and m3u file. So I can visit radio sites e.g. http://www.slayradio.org and simply click on the play icon.
    I only stream videos from my satellite receivers and there I simply open the web interface, click onto the stream button and mplayer pops up playing the stream.
    Geit
  • »19.12.09 - 18:24
    osco
    Here is a translated article to configure getVideo with the OWB browser
    http://obligement.free.fr/articles/getvideo_owb.php
    Installling getVideo:
    1. Requirements:
    * working ARexx setup
    Yes Rexxmast is in the startup sequence!
    There was a mention to rename a tool rexxsyslib and install another from older resxxlib?
    Yes got an old 1999 rexxlib and copied it
    * a TCP/IP stack with a working TCP handler
    MorphOS has it?
    Yes it was in the User Startup!
    * some cli commands (filenote,delete,touch,requestchoice,requestfile)
    Are the part of the DOS?
    Guess so forgot to look for them inC:!
    * wget command in your system path or another path (setup required)
    What's the system path? Is that the C: Directory? exact path please?
    Copied into C:
    * mplayer for playing FLV files. mplayer must be in system path or
    Again the C: directory?
    * rtmpdump (prefered) or flvstreamer in your system path or another
    path (setup required) - this is only needed for some of the supported
    sites.
    Not a clue for "rtmpdump"?
    The article above says to put the commands in the C: directory What C: directory? exactly the path?
    How do you copy files into the C: directory?
    How many C: directories in the OS?
    I see the files only by "ED" not by ambient?
     8-)  8-)  8-)  8-)  8-)  8-)  8-)
    [ Edited by osco on 2009/12/19 20:24 ]
    [ Edited by osco on 2009/12/20 20:24 ]
  • »19.12.09 - 23:10
    xyphoid
    use only the cubed morph icon not sys:mossys, and c is in it
    rename rexxsyslib to rexxsyslib.library_old, and get the original 1.3-3.9 rexxsyslib search net
    (renaming may have to be done in mossys, but while there do not fool around)
    * go to user-startup and edit it with ed. add... mount tcp:
    * go to aminet and d/l wget, then place it in cubed C:
    *better yet just go here https://morph.zone/modules/newbb_plus/viewtopic.php?forum=9&topic_id=6391&sortname=&sortorder=&sortdays=&viewmode=flat&order=0&start=0
    https://morph.zone/modules/newbb_plus/reply.php?forum=3&post_id=68802&topic_id=6734&viewmode=flat&order=0
  • »20.12.09 - 00:12
    Posts: 837 from 2007/10/23
    By the way you already have wget :-)
    list owb-morphos-1.6.1/datas/wget
  • »20.12.09 - 02:04
    GMKai
    Posts: 257 from 2003/4/7
    @geit:
    what steps did you take to make owb pass the playlist to mplayer?
  • »20.12.09 - 08:03
    Korni
    Posts: 473 from 2006/2/23
    There is a readme inside getVideo archive. Path to MPlayer and additional options can be configured in getVideo.cfg,
  • »20.12.09 - 08:05
    GMKai
    can getvideo really handle .m3u and pls-files?
  • »20.12.09 - 08:58
    Korni
    You can set actions for MIME types in OWB settings (almost like in Ambient). This way you can view pictures via ShowGirls, load playlists into MPlayer and so on.
  • »20.12.09 - 09:26
  • Fab
    Fab
    Posts: 1331 from 2003/6/16
    You need to pass playlists with -playlist <path to playlist>.
  • »20.12.09 - 11:29
