morphos -virtualbox
    Posts: 6 from 2009/9/16
    Hi!
    I have ubuntu 9.10 and I want to install MorphOS on virtualbox.
    what is the procedure?
    thank you
  • »16.09.09 - 08:28
    Golem
    Posts: 766 from 2003/2/28
    Go here, then adapt virtualbox so it emulates a supported platform.
  • »16.09.09 - 08:33
    can you help me please
    I tried the OS available, but on boot it does not detect iso image morphos
  • »16.09.09 - 08:52
    Golem
    You need supported hardware, virtualbox does not qualify. Check the link I gave.
  • »16.09.09 - 08:56
    what is vmware server might work?
    I just want to virtualize
    is it possible to install wallget on windows or linux
    thanks
    [ Edited by hdzpeter on 2009/9/16 12:10 ]
  • »16.09.09 - 09:08
    analogkid
    Posts: 713 from 2004/11/3
    @hdzpeter:
    no chance, no solution like virtualbox, vmware or qemu will work for now. you have to buy a supported mainboard/system like the pegasos1/pegasos2 or efika (and mac mini in the hopefully not so far future).
  • »16.09.09 - 09:14
    Golem
    No.
    MorphOS is not for you then, it requires one of the supported PowerPC platforms, as in not your x86(-64) PC or whatever. Here is a link (again) with a description of the supported hardware.
  • »16.09.09 - 09:14
    Senex
    Posts: 500 from 2003/2/17
    @hdzpeter
    While there seems to exist an internal version of qemu (Screenshot), unfortunately it's not available to the public.
    A possible reason has just been given in another thread:
    "Running MorphOS inside a virtual machine would not be compatible with the concept of requiring a keyfile that is locked to a particular hardware setup."
  • »16.09.09 - 09:41
    thanks for your reponses
    one more question is it possible to install wallget http://obligement.free.fr on windows or linux
  • »16.09.09 - 10:31
    Golem
    You could probably run the m68k version under UAE.
  • »16.09.09 - 11:36
    thanks
    i try this
  • »16.09.09 - 12:10
    jcmarcos
    Posts: 1178 from 2003/3/13
    You like walget so much that you want to install the operating system it runs on? Wow, first time I hear something like that! Don't you have a similar tool for your current operating system?
  • »17.09.09 - 09:30
