MorphOS Developer
Posts: 1099 from 2004/9/23
Regarding Screenbars it is usually some third-party screen bar module causing issues.
It does not even matter if a screen bar module is active or not. So with those modules I would simply rename the entire sys:Classes/Screenbar directory and reboot to see if there is a difference. Then create a new Screenbar directory and move the old contents one by one with a reboot in between to find the culprit.
