E-UAE with 2 or 4 joysticks support simultanely ?
    Posts: 478 from 2019/5/9
    Slightly offtopic, but please, what nice Amiga games are for four joysticks?
  • »06.08.21 - 06:56
    Thanks, that is nice!
  • »06.08.21 - 07:29
    Posts: 848 from 2007/10/23
    At least UAE's inputdevice.c says
    "supports parallel port joystick adapter"
    [ Editiert durch polluks 07.08.2021 - 00:48 ]
  • »06.08.21 - 08:34
    Cool_amigaN
    Posts: 777 from 2011/11/30
    Papi go to prefs/usb/devices and setup your joysticks as described here. Remember that one joystick should be "Merged with USB" at port 0 (leaving all the other ports as "Don't touch") and the other "Merge with USB"at port 1 (leaving all other ports 0,2,3 as "Don't touch").
    Then go to .uaerc conf file and edit:
    joyport0=joy0
    joyport1=joy1
    Now, both joysticks should be operational.
    On the other hand, our e-uae unfortunately doesn't support more than 2 joyports :( Therefore games like Beach Volley, Kick Off 2, DynaBlaster, Tip Off, Skidmarks and more (the list you posted is incomplete) which support up to 4 players simultaneously are out of the picture.
    Which is very sad given we have dual mirroring screens and the setup could be optimal for Amiga parties gaming sessions :/
    edit: if 2 joysticks control same player while ingame, it means you have setup the ports on prefs/usb/devices/settings of both joysticks on the same port!
    [ Edited by Cool_amigaN 06.08.2021 - 22:49 ]
  • »06.08.21 - 17:28
    Indeed, you can try a patched lowlevel.library
    ll4player
    However E-UAE is missing parallel port emulation :-(
    [ Editiert durch polluks 08.08.2021 - 15:06 ]
  • »08.08.21 - 09:16
    Papiosaur
    Posts: 2615 from 2003/4/10
    Maybe is possible to take sources of others Amiga emulator supporting parallel adaptator for Joystick ?
  • »09.08.21 - 05:12
