Chrysalis pack for MorphOS 3.13
    Templario
    Posts: 561 from 2012/4/28
    Papiosaur escribió:
    Hello all,
    i'm updating software from Chrysalis pack for MorphOS 3.13.
    Don't hesitate to do suggestions to improve it here ;-)
    Thanks !
    Well, one date of official launch? because I'm work in Font Tester and Pintor Web.
  • »12.02.20 - 15:24
    Papiosaur wrote:
    Hi Templario,
    I wait your updated version of Font Tester and PintorWeb ;-)
    Why wait? If Grunch is included in the Chrysalis Pack for MorphOS3.13, then the users can update to the latest versions of each program immediately after they complete the installation of the Chrysalis Pack.
  • »12.02.20 - 19:06
    Templario
    Papiosaur escribió:
    Hi amigadave,
    i think Templario don't have Grunch database.
    Templario ?
    No, I haven't Grunch database I don't got make a database that works with Grunch only a bad experiment and waste of time.
  • »13.02.20 - 09:44
    Papiosaur wrote:
    Hi amigadave,
    Templario ?
    Programmers who write software for MorphOS that don't want to use Grunch to keep their software up to date should then provide another means to easily update their programs. Either way, I don't think that your Chrysalis Pack should be held back until a new version of anything is ready to include, unless the programmer contacts you privately and asks you to wait a few days, so they can finish up the last few lines of code to fix bugs in their latest version of some project. I hope that you aren't putting software into the Chrysalis Pack that has not been tested for at least a couple weeks by several people. Having buggy software included in the Chrysalis Pack would be a bad reflection not only on the Chrysalis Pack and yourself, but could be a bad reflection on MorphOS, for new users who don't know that the Chrysalis Pack is independent and not associated with the MorphOS Development Team.
  • »13.02.20 - 16:39
    Posts: 12568 from 2003/5/22
    > buggy software included in the Chrysalis Pack [...] could be a bad reflection
    If it's not already there, a disclaimer that tells this in no uncertain terms at the begin of the Chrysalis installation could help prevent such misconceptions.
  • »13.02.20 - 16:54
    Papiosaur
    Posts: 2615 from 2003/4/10
    Thanks amigadave for your return.
    I will add your comment in the readme and the installer script : Chrysalis pack is independent and not associated with the MorphOS Development Team. If an user found a bug in a software, he can contact the author.
  • »13.02.20 - 17:02
    Papiosaur
    Hello all,
    a version to test is available here :
    www.morphos-storage.net/upload/chrysalis.iso
    You need to have a fresh install of MorphOS 3.13.
    Don't hesitate to do returns, suggestions here ;-)
    Thanks
    This is the changelist:
    AmiSpeedTest 0.6
    AmiSSL 4.4
    FontTester 1..05
    GrimoriumPDF 2.10
    Hatari 2.2.1
    Iris beta71
    Leu 0.08
    MorphOS 3.13 ixemul hotfix
    RNOComics_1.5
    RNOEffects_1.3
    RNOTags_1.1
    RNOWidgets_1.4
    ScoutNG_1.5
    Screenshot screenbar 1.1
    ScummVM_2.1.1
    SDL2
    TopTasks_1.3
    Unrar_5.80
    VidentiumPicta_2.20
    WebRadio_1.11
    Wings Demo
    [ Edité par Papiosaur 28.02.2020 - 17:09 ]
  • »28.02.20 - 13:35
    Papiosaur wrote:
    Hello all,
    Thanks
    Thanks for your work on this Pack, and also for your work supporting all MorphOS Team members, and third party programmers.
  • »28.02.20 - 17:50
    Spihunter
    Posts: 84 from 2003/7/9
    How fresh of a 3.13 install does it have to be? I've only installed a couple of audio apps on mine. Nothing system changing.
    17" Powerbook. MorphOS registered
    Hear my music here: Gordon Gallant
    And here: Kattalax
  • »29.02.20 - 13:54
    redrumloa
    Posts: 1424 from 2003/4/13
    Trying to start Mame from the dropdown errors out with:
    Could Not Start Program
    (gives path)
  • »04.03.20 - 23:28
