Posts: 1576 from 2012/11/9
You have to bear in mind that your printer does not seem to be in the
MorphOS Supported Hardware - Scroll down to Printers but it may be supported if it is hardware compatible with a HP or Epson printer in the list, though sadly I doubt that there is a compatible printer option, but I could be mistaken.
However, if you can, then you'll be able to use TurboPrint to print out document you select/save to print, either using the TurboPrint driver for the printer or using the GS: (GhostScript, i.e. PostScript emulator printing capability of TurboPrint), although there is also a specific version of Ghostscript for MorphOS you can download if you prefer.
You can also take a look at the MorphOS Library in the
Hardware Compatibility - User supplied informationI don't use Turboprint as I have a PostScript capable colour laser printer (HP2500 CLJ) that I usually use via USB, though I could use the Netprinter.device, but I don't print out as many documents as I used to, so USB suits my needs quite nicely.
PostScript printing has had improved support recently since v3.10, so if you can acquire a PostScript printer, with a PPD file that you'll need to get it working with MorphOS then you'll be far better off, and generally get better quality printouts than PCL3.
I hope the information is of some use to you.
[ Edited by NewSense 15.08.2018 - 04:39 ]MacMini 1.5GHz,64MB VRAM, PowerBooks A1138/9 (Model 5,8/9),PowerMac G5 2.3GHz(DP), iMac A1145 2.1GHz 20", all with MorphOS v3.19+,Airport,Bluetooth,A1016 Keyboard,T-RB22 Mouse,DVD-RW-DL,MiniMax,Firewire/USB2 & MacOSX 10.4/5
