TARGA datatype for MorphOS
  • MDW
    MDW
    Posts: 498 from 2003/7/25
    I am looking for TARGA datatype for MorphOS. My datatype loads grayscale images incorrectly. I am almost sure this is endian-bug in the datatype. Does anyone have better TARGA datatype? Maybe native version for MorphOS?
  • »19.05.17 - 18:12
    _bigdan_
    Posts: 70 from 2009/1/7
    Could you check the size and version of your targa datatype file ?
    Which app did you tested (Visage, Showgirls, Multiview, etc.) ? Thanks in advance.
  • »20.05.17 - 11:25
    Posts: 848 from 2007/10/23
    Indeed, Reggae's targa.decoder is broken
    example
    bug reported
    [ Editiert durch polluks 20.05.2017 - 18:27 ]
  • »20.05.17 - 12:49
    Posts: 903 from 2003/3/4
    v43.1 on Aminet is the only datatype I ever knew, sorry.
    Even though TGA is a simple fileformat, it's so rare that there was never any real interest in an updated datatype or reggae viewer.
  • »20.05.17 - 13:17
    Posts: 611 from 2003/4/11
    Actually, there has been some bug in the Reggae targa.demuxer, it has been fixed for the next update, thanks for reporting.
  • »21.05.17 - 12:57
  • MDW
    MDW
    file: SYS:Classes/Datatypes/targa.datatype
    version: Couldn't find version string
    I have tried: Showgirls, MultiView and standard MorphOS 3.9 image viewer.
  • »21.05.17 - 18:44
  • MDW
    MDW
    Thank you! I am happy. :)
    I have already implemented myown function for loading Targa format and... I made probably the same bug. :) I was very surprised when I showed grayscale Targa using dataypes and I saw the same effect like in my buggy implementation.
  • »21.05.17 - 18:53
    Posts: 12569 from 2003/5/22
    > LoView
    It's Mysticview.
  • »22.07.17 - 17:53
