French in menus and other questions
    Posts: 8 from 2017/2/3
    It's taking time but I'm slowly configuring MorphOS and the Chrysalis add-ons. Everything is going well but still have a few questions:
    When I right click on a .lha file to extract, much of the context menu is in English (copy, cut, paste) but other things especially on the bottom of the menu are in French (like Extract and Extract Here, Open in EUAE etc). Is there any way to get everything back to English?
    A second question, is there a good ANIM player for MorphOS? I have many ANIM files I'd like to watch (and some work great though I can't modify the playback speed) which leads me to my next question...
    How does one associate a filetype to open with a specific application? It'd be great to double click the .anim files and have them open up a player automatically.
    Thanks for all the help!
    Pierre
  • »01.03.17 - 14:47
    Posts: 2220 from 2003/2/24
    I'd check Ambient's Mime settings... for example application/lha, application/x-adf etc. You can change them manually, but it would be good to give feedback to Chrysalis author to fix these things too :)
    I haven't tried to play any iff anims, buut.. at least found some suggestion from an old thread.
    Here are some examples:
    http://library.morph.zone/Getting_Started#Setting_MPlayer_as_the_Default_Player_on_Ambient
    http://library.morph.zone/Getting_Started#Setting_Jukebox_as_the_Default_Player_for_MP3_Files
    video/x-anim seems to be the type to edit from Ambient's Mime settings...
  • »01.03.17 - 15:42
    Posts: 12566 from 2003/5/22
    "UP/DOWN arrow keys: To rise or lower the speed for animations show in FPS."
    http://www.morguesoft.eu/Paginas/vamp.htm
  • »01.03.17 - 22:00
    I got inspired of this anim player issue... I'll make a dedicated iff/gif anim player with Hollywood and it can be added to mime types easily, just give me few days :)
  • »02.03.17 - 15:28
    Player part is already done, but I started to add anim format conversion functions etc, so it takes little more to finetune :) I'll have a few days pause, but if someone is in a hurry and wants a beta version, msg me. Anyway, Hollywood rules and allows this kind of "rapid" software development, kind of an AMOS of today, but much better :)
    The player will feature:
    - MUI-GUI
    - Loads IFF Anims, GIF anims, AVI/MJPEG, and with plugins some other formats too (APNG, Flic, Movie Setter, YAFA...)
    - Saves to GIF, APNG, AVI/MJPEG
    - Full ARexx controlling
    - Shell arguments
    - Adjustable speed (by factor or by framerate)
    - Keyboard controls
    - Zooming to different sizes
    - And some more...
  • »10.03.17 - 14:57
    Papiosaur wrote:
    @jPV: it possible to update your beta on MorphOS-Storage ?
    No, I want to make a proper release when it's finished. It won't take that long, week or two.
  • »10.03.17 - 16:42
    igracki
    Posts: 471 from 2003/2/24
    Could you also support creating gif anims from single images?
  • »11.03.17 - 11:32
    Should be possible. I've also been thinking about it, at least if there's enough interest... I'll have to think better if I need redesign the GUI much for that or could I implement with the current compact player-like design.
    With the current program you already can also convert animations to different sizes. If you resize the window, animation gets scaled, and if you save the animation it gets saved in the new size. Also the speed settings will affect to the saved animation. Delays between single frames will be adjustable soon too.
  • »11.03.17 - 13:29
    Ok, had some delays, but it's out now:
    https://morph.zone/modules/news/article_storyid_2327.html
    Animations can be created from single images, but animations can also be exported to single images. The program is easy to integrate with Ambient... if you don't have existing filetypes, installing with Grunch does it automatically for you. The program also detects if it's already running, so you can just go doubleclicking anims from Ambient and they get loaded to running instance, no need to quit in between etc.
  • »02.04.17 - 14:06
