How do I grab a screen in MorphOS
    Punkyclown
    Posts: 37 from 2015/2/15
    Can someone please tell me how to grab a screen in MorphOS? I know lately I have been
    a pain in the Axx with all these mundane questions. Hopefully with the completion of
    my article we will get into increased interest in MorphOS.
    Thanks to all
    Brad Hansen
  • »15.11.16 - 17:15
    beworld
    Posts: 683 from 2010/2/10
    you can use this : http://library.morph.zone/Utilities/Grabber
    My MOS ports
  • »15.11.16 - 17:26
    Posts: 1390 from 2010/1/6
    Or http://morphos-files.net/remote/SnapIt
  • »15.11.16 - 17:28
    Posts: 1362 from 2004/2/8
    The easiest way is to run
    System:Utilities/Grabber
    Then select a screen/window to grab and hit "Save". Your grabbed file will be saved to RAM:Grab.png by default, or anywhere you like if you change the path/name.
  • »15.11.16 - 17:44
    Posts: 1099 from 2004/9/23
    MorphOS 3.10 will also contain a grabber screenbar module. </spoiler alert>
  • »15.11.16 - 17:45
    Posts: 12569 from 2003/5/22
    Nice. I can retire SchnitzelSchnäpper then :-)
  • »15.11.16 - 20:04
    Punkyclown
    Great! Appreciate the feedback.
    Brad Hansen
  • »17.11.16 - 18:29
    Punkyclown
    Brad Hansen
  • »17.11.16 - 18:33
    Templario
    Posts: 561 from 2012/4/28
    Brad Hansen
    Grabber is the best option and you can select the output format file, png, jpg.
  • »19.11.16 - 17:05
