Updating Morphos without burning ISO cd
    Fairdinkem
    Posts: 42 from 2010/8/20
    Hi everyone,
    I have a Pegasos 2 and I would like to hope it is possible to update to the latest MorphOS without burning the ISO to a CD which is annoying and wasteful considering the frequency of late with the updates.
    Would someone be so kind to give me a step by step guide which is idiot proof to help me?
    Also would it be okay to go from MorphOS 3.4 to the latest 3.7?
    Thanks in advance.
  • »11.08.14 - 06:32
    Senex
    Posts: 500 from 2003/2/17
    Thomas Rapp described updating without burning a CD here.
    Updating from 3.4 to 3.7 directly is no problem.
  • »11.08.14 - 07:11
    Posts: 1099 from 2004/9/23
    Just use a CDRW and nothing is wasted. Once you have a non booting system for no reason you are thankful to have a recent recovery disc.
    Since MorphOS ISO contains the entire OS, you can update all installed systems starting with 2.0 by any successor.
    Geit
  • »11.08.14 - 07:30
    Fairdinkem
    Well I found a blank disc and did the update wish we had the option of a downloadable intaller system to update with but I do understand the benifits of ISO also.
  • »11.08.14 - 09:13
    Posts: 3336 from 2003/3/5
    This procedure is very wrong and will not work with 3.8. Please always use the officially supported update methods.
  • »11.08.14 - 09:46
    Cool_amigaN
    Posts: 777 from 2011/11/30
    @jacadcaps
    It didn't even worked correctly with the current version.
    I know it cause after renaming the old boot.img and copied manually the newer, I got a non working system :/
    Later I had to manually boot the correct img from cd via OF in order to get my system back at its feet.
  • »12.08.14 - 06:41
    This is exactly why we always ask our users always to follow the official update route, be it via USB or a CD.
  • »12.08.14 - 06:43
    Cool_amigaN
    @jacadcaps
    Well, I had to try for one more time before ultimately giving up that useful install hack by Tomas, once and for all :P
  • »12.08.14 - 06:49
    zohaa
    Posts: 1 from 2014/10/16
    Since I have to do a reinstall of 3.7 to see if Chrysalis makes my G5 unstable, I figured I'd make use of my G5 with Debian and MorphOS.
    Anyone have notes on this?
    Sign up with Florida National University for getting incredible online 642-813 courses exam and University of Toronto.
  • »16.10.14 - 19:32
