SuperBundle Help!
  • Targhan
    Posts: 2833 from 2003/2/7
    Just making a topic for help that may be needed for SuperBundle issues. Please feel free to ask away!
    :idea:Targhan
  • »01.08.03 - 15:57
    Senex
    Posts: 498 from 2003/2/17
    First question: Are there any sample projects downloadable for ProStation Audio to get familar with this program?
  • »01.08.03 - 19:30
    realstar
    Posts: 298 from 2003/2/24
    Can anyone confirm a working scanner under
    FXScan lite? I tried an HP5200C under the
    "BetaScan" driver and usbraw.device without
    any luck. I am considering an Epson 1660 Photo,
    since it's the only model I can find that is
    listed as directly supported. If anyone is using
    a scanner under MorphOS, I would like to know. :)
  • »02.08.03 - 00:47
  • Targhan
    1. Good question about PSA. Will someone step up to the podium?
    2. I have a scanner, but haven't tried it yet. I will this weekend. *edit: I couldn't get my Visioneer One Touch to work* It's all I have to work with righ now...
    :idea:Targhan
  • »02.08.03 - 02:19
    Trizt
    Posts: 17 from 2003/6/1
    Is the registration form working at all, now I have been waiting for 36 hours and still I haven't got the reply that was claimed to be sent right a way after filling the form. :-x
  • »02.08.03 - 03:47
  • Targhan
    @Trizt
    Please, just try again. You should see a reply shortly. If not, mail to the webmaster of PegasosPPC.com. If *That* doesn't work, please come back here and let me know.
    :idea:Targhan
  • »02.08.03 - 04:49
    BatteMan
    Posts: 290 from 2003/2/24
    I'm using an Espon Perferction 1660 Photo with my Pegasos and with FXScan (but not the lite version :p ).
    All works, but I don't find how i can activate the lamp for negatif's photo...
    If you take this scan, go to the site of iospirit, here : LINK
    It's the procedure to install it on Poseidon, on the pegasos of course.
    PS: 'scuce me for my poor english :)
    [edited by: Targhan]
    [reason: Make link active. Reduce width of page(hopefully).]
  • »02.08.03 - 05:42
    realstar
    OK, I bought an Epson 1660 Photo and still can not seem to get it to
    work. I just get the message "unknown error opening device",
    "communication with scanner failed". Any idea of what I can try? I
    am setting "EpsonUSB.device" as a scanner driver and "usbraw.device"
    as the device. It doesn't show any units listed in the FXScan
    interface.
    Update: The rawwrap.class is bound to the epson scanner now.
    FXScan still doesn't recognize anything on usbraw.device though. :(
  • »02.08.03 - 23:20
    Posts: 126 from 2003/2/17
    use iousbscanner.device IIRC.... look at iousb documentation :)
  • »03.08.03 - 04:21
    realstar
    MorphOS doesn't use the "iousbscanner.device" but
    instead uses the "rawwrap.class" and "usbraw.device"
    that is located in memory according to the faq on the
    iospirit website.
  • »03.08.03 - 05:16
    todi
    Posts: 140 from 2003/2/18
    @Senex
    did you try the Tutorial 1, it's also available as .lha with all audio-files.
    A quick search on aminet shows, there's also a second tutorial available! :-D
    And there is a 4 part german workshop in the AMIGA plus 10/2002 - 01/2003!  :-o
    Is that enough for a start?  8-)
    ToDi
    amigazeux.org
  • »04.08.03 - 20:29
    realstar
    Anyway, I returned the Epson scanner and bought a
    cheaper HP2200c model that works on linux. In
    the meantime I will work on porting the "plustek"
    sane backend to MorphOS so that I can use it
    on MorphOS too. :)
  • »04.08.03 - 23:19
    Senex
    @todi
    Yes, of course I had found the tutorial on the PSA homepage (thanks for pointing to the 2nd one), but I'd been rather thinking of a complete project one could just load and have a quick impression by just hitting "play".
    Seems I have no other choice then to actually study those tutorials and also having a look at the A+ (thank you for the hint).
  • »05.08.03 - 02:34
    Posts: 157 from 2003/3/3
    Senex: Would help helluva lot if people were allowed to use that program. But as you know, it does not work on Mos1.3 and ...  :-(
    http://somequicknotes.blogspot.com/index.html
  • »05.08.03 - 06:12
    Robert
    Posts: 331 from 2003/5/12
    I'm still not able to download it.
    Finally got my response to the password request - unable to verify
    your details!
    Waaaaaaaaaaaaaaaaaaaaaahhhhhhhhhhhhh! :cry:
    I've sent back a brief synopsis of my long-running saga, so hopefully
    that'll do the trick.
    Robert.
    (still itching for a go at PSA.............)
    Robert.
  • »06.09.03 - 17:25
    Ritty
    Posts: 29 from 2003/8/24
    @JoannaK
    if you were to configure a Pegasos with MOS ... for 2D and 3D...and video animation ... what would be your Ideal set-up ...assuming a scanner , and a graphics tablet, and printer are already there .... what programs ... graphics cards ,etc... thanks
  • »06.09.03 - 22:26
    Ritty
    hi .... i asked , but no answers??? well; thanks anyway , i know a webmaster is busy .......
  • »11.09.03 - 02:02
  • Targhan
    C'mon now, I'm not usually in every thread folks :-) I would feel like "Big Brother" if I was! Ok, I fixed the width of this page by making a certain LOOONG url a link ;-) Here is how you make a link:
    [ url=https://morph.zone]Linked Text[/url ]
    Just remove the extra spaces around the brackets "[". That's all there is to it!
    :idea:Targhan
  • »11.09.03 - 04:13
    nels664868
    Posts: 117 from 2003/12/28
    I applied for Super bundle Download Dec 14 2003 and emailed support@morph.net on jan 4 2004 to ask about the hold up, but have recevied nothing in reply.
    Ask Dr. Stupid,
    Dear Dr. Stupid,
    Why do we have to go to school?
    That's a very good question. It's becuse your parents are
    ALIENS!!! When your at school they shed there human skins and
    breathe drier lint! hahahaha!
  • »07.01.04 - 21:14
  • Targhan
    nels
    send me your information privately (email/pm), and I will look into what is going on for you.
    BTW, I verified that IBrowse2.3 (regged) does work with the PegPPC logins, but Voyager3.4 does not. It WILL be fixed. Someway. Somehow.
    :idea:Targhan
  • »08.01.04 - 02:21
  • -D-
    -D-
    Posts: 118 from 2003/5/1
    Can anybody recommend whom at Genesi to email about access
    to the Superbundle?
    I applied on 1 January (and haven't heard back yet), but heard they had some problems with
    registration...so perhaps they lost my information?
  • »25.01.04 - 22:23
    MaSC
    Posts: 63 from 2003/12/1
    to the Superbundle?
    I had the same problem and emailed:
    support AT morphos DOT net
    And it was sorted out within a few days
    While I'm here, how do I get MorphED? I know it's available from the MDC but I thought it was part of the superbundle for non-developers aswell (atleast thats the impression I got from the Total Amiga review)?
  • »25.01.04 - 22:34
