                Posts: 408 from 2004/7/15
				Hey, probably it supports IrTranP or IRObEx. They are also standard protocols. So don't worry. Usually infrared devices are standard.
 I say "Usually" because i investigated wired protocols of different cellular phones and came to a conclusion that many manufacturers don't follow standards there and implement their own proprietary protocols supported by only some kind of rubbish Windows utility. So there's a small chance that Siemens does this with infrared port too.
 But you should try.
 And the last point. If you want to take quality pictures, get rid of your phone and get a normal camera. Really.
iPod, iBook, iMac,... iRobot?
