whdlopener
    Minuous
    Posts: 163 from 2010/2/12
    @g0ldf1sh:
    Using a search engine it is not hard to find Kickstart ROMs for download. Or you can use the TransROM program which is included with WinUAE.
  • »13.12.18 - 10:05
    outlawal2
    Posts: 88 from 2009/5/6
    And another awesome thread in the universe of Amiga land...
    "I would think the message is self-explanatory? "
    Yeah that was REAL helpful.. And whether it was or was not you still provided absolutely NOTHING of value in answer to the question. Par for the course..
    And then my special favorite
    "Google it.."
    Well yeah because no one has EVER thought of that before coming to a forum for help, right?
    Why do you jokers even bother with a forum if you are going to continuously treat people this way?
    [ Edited by outlawal2 13.12.2018 - 07:52 ]
    "Pride is a poor substitute for intelligence." Quote from Rambo...
  • »13.12.18 - 11:27
    Minuous
    >telling him to google it to find ROMs online is piracy
    Of course it isn't.
    >Not to mention that he has already paid for the ROMS with Amiga Forever
    So if he already owns the original hardware, AND has bought Amiga Forever, he has already paid for the Kickstart licence TWICE. And you still would have a problem with him downloading it!? I think you must be the joker.
  • »13.12.18 - 12:30
    outlawal2
    Hmmmmm... I think there are still some legalities here and GOD KNOWS legal stuff is a bitch...
    But I am going to edit my post and remove this portion as I see your logic even though I am not sure the law cares much about logic.
    Either way you made your point..
    None of this however; excuses folks for treating people poorly.
    If you are too tired or sick of questions, whatever then just shut up and let someone else provide some useful comments.
    [ Edited by outlawal2 13.12.2018 - 07:54 ]
  • »13.12.18 - 12:51
    Korni
    Posts: 472 from 2006/2/23
    BTW. If it's just a matter of a "one line" change and someone is willing to test the installation process then I can add support for Cloanto ROMs in a installer script. I will add a link to a new script here later.
    [ Edited by Korni 13.12.2018 - 15:00 ]
  • »13.12.18 - 12:58
    Posts: 891 from 2003/3/4
    The message accurately and succintly provided the relevant information: that the Cloanto rom was encrypted, and that the file path had to be set for the keyfile.
    What else do you want it to do? Load a youtube video?
  • »13.12.18 - 15:36
    Of course it isn't.
    Unless he buys it from Hyperion that is :)
  • »13.12.18 - 15:39
    g01df1sh
    Posts: 36 from 2015/5/28
    Korni wrote:
    g01df1sh wrote:
    Please explain message is not helpful
    It works with Commodore kickstart ROM image files. ROMs from Cloanto are not supported by the installer script, because I simply don't have them.
    Try adding a path to a .key file
    kickstart_key_file=SYS:Emulation/E-UAE/ROMs/rom.key
    to your e-uae config. Also check E-UAE documentation.
    Fantastic it works thanks for your useful tip. Also found a good blog to help with screen settings and joypad enable.
    https://amigax5000.blog/2018/08/17/whdlopener/
    Now in 2018 I have a nice portable Amiga system with some new apps/games and access to all the good classics with just a mouse click away.
  • »13.12.18 - 16:05
    g01df1sh
    I can confirm it was just a matter of adding the path to the key file.
  • »13.12.18 - 16:09
    outlawal2
    Maybe provide something of value maybe?
    You sir are a complete ass.
  • »13.12.18 - 17:53
    g01df1sh
    Hi
    So far i have a few games working Slamtilt , projectx se, superfrog, xenon megablast. I tried jum n roll and get a workbench requester saying . dos error (obejct not found) on reading jump. Any ideas a whole load of other games I have come up with similar errors.
    The games that do work have been done by just copying the whdload game folder to my games folder on my hard drive
    Hope you clever guys can make sence of this...
  • »13.12.18 - 18:02
    Korni
    Probably caused by 'N', remove both ' from filename and it should start.
  • »13.12.18 - 18:05
    g01df1sh
    sorry change of name did not help. Thanks for idea though
    Same message unable to find jump :(
  • »13.12.18 - 19:19
    Korni
    Check tooltype for the game icon if the slave name is correct. Do you actually run it from the same volume as the other games that are working? If that volume wasn't present during whdlopener installation you need to add path to volume by hand to euae config or reinstall (it's in the readme).
    [ Edited by Korni 13.12.2018 - 21:39 ]
  • »13.12.18 - 19:39
    g01df1sh
    Hi
    Its copied into the same location as the other games that are working
  • »13.12.18 - 20:34
    Korni
    Just tried it myself. Do you have "Jnroll" file inside (~64KB)? I got the same message with this file renamed.
    [ Edited by Korni 13.12.2018 - 23:40 ]
  • »13.12.18 - 21:14
    g01df1sh
    HI Yes I have the jnroll. file
    Thanks for looking into this
  • »13.12.18 - 21:51
    Korni
    "jnroll." or "jnroll"? If the latter and rwed flags are set and it still doesn't work, then your whdload games seem to be simply broken.
  • »13.12.18 - 22:59
    g01df1sh
    Mine has a . at the end
  • »14.12.18 - 07:56
    Korni
    Rename jnroll. to jnroll
  • »14.12.18 - 09:31
    g01df1sh
    Hi I will try renaming it tonight thanks.
  • »14.12.18 - 10:39
    g01df1sh
    Hi
    Thanks so much renaming the file has fixed jump and roll. Now that bloody start up chime to deal with. Is there a way of accessing terminal using the osx install cd. When I boot of it all the options i have is just to install the os am I missing a trick. If not I will have to stick in another drive and install osx and disable the chime and then put back my Morphos drive.
  • »14.12.18 - 18:23
    g01df1sh
    HI
    Another little whdlopener question. I have tried Breathless it loads all ok but is dog slow even using 2x2 pixels is this due to jit not being enabled? how easy is it to enable or will it mess up my other games.
  • »15.12.18 - 20:23
    Korni
    020 AGA w/ FAST mem is used by default. 040 and 040 JIT example settings are included with e-uae.
  • »16.12.18 - 08:13
    g01df1sh
    how do I tell it to use the jit settings? can I just rename it to the one that is is being used now and make my current one called A1200-020 for example
  • »16.12.18 - 18:19
