whdlopener
    Korni
    Posts: 471 from 2006/2/23
    Edit A1200_WHDLoad.conf or A1200_WHDLoad_window.conf (available via context menu for slave files).
    Change 68020 to 68040. Maybe it will be enough.
    For JIT (copy pasted from the readme):
    cpu_speed=max
    cpu_type=68020 (or 68EC020, 68040, 68060, see Known issues)
    cpu_compatible=false
    cpu_cycle_exact=false
    blitter_cycle_exact=false
    cachesize=8192 (or higher)
    comp_constjump=yes
    comp_trustbyte=indirect (see Known issues)
    comp_trustword=indirect
    comp_trustlong=indirect
  • »16.12.18 - 23:17
    g01df1sh
    Posts: 36 from 2015/5/28
    Hi
    Jit has helped but stil to much lag on 1x1 pixels to be playable.
  • »17.12.18 - 23:56
    Korni
    Runs ok with 040 and JIT. On a G4 1.67GHz. In MorphOS Preferences - Laptop: Make sure "Adjust CPU frequency between full and half speed" is enabled, otherwise it runs at half speed only.
  • »18.12.18 - 23:52
    g01df1sh
    Hi
    Found the setting I ticked both boxes for mains and battery.
    What are your GFX settings in uae conf file for screen sizes
    Mine is a 1.33GHZ version would that make much difference
    [ Edited by g01df1sh 18.12.2018 - 23:05 ]
  • »18.12.18 - 23:55
    Korni
    g01df1sh wrote:
    Hi
    I don't remember if 1.33 has frequency scaling, but you can and check in laptop settings anyway.
    I use the same settings as the ones provided with whdlopener, so 320x256. On a powerbook with a 1280x854 matrix I also have a 320x214 screenmode, some games can be cut though.
  • »19.12.18 - 00:19
    Posts: 12079 from 2003/5/22
    DFS2 is only supported on 1.67 GHz models, unless something silently changed in this regard with MorphOS 3.10 or 3.11.
  • »19.12.18 - 12:01
    g01df1sh
    Hi
    If i set it to 320 x 256 I end up with a little screen in the middle of the screen and the game menus do not fit to the screen..
    Sorry for being a noob
  • »19.12.18 - 21:49
    g01df1sh
    Hi
    Thanks for overlay tip I give it a go tonight
  • »20.12.18 - 15:49
    g01df1sh
    Added command to top of config file has made no difference still small screen
  • »20.12.18 - 18:51
    Korni
    http://korni.ppa.pl/temp/WHDLOpener-test.lha.xz
    Added support for encrypted kickstart ROM images. Need confirmation if it works as I only have kickstarts from C=.
  • »24.12.18 - 17:36
    Korni
    Thx Papiosaur. Updated configs in e-uae archive.
  • »05.01.19 - 19:26
