Finally I buy a second MacMini at Ebay. Exact same model as before (1,5GHz 1GB RAM with 80 GB HDD). I found out that RAM of this 2nd MM is defect and CD-ROM reads much much worser than the CD from my 1st MM. But this are issues that I can fix with replacement parts in future if I will.
Anyway I used this 2nd MM to cross check/replace all the components step by step with the 1st MM (the power supply, the HDD, the SSD, the CD-Drive, the logic board and this mini bridge board that connects CD/HDD to logic board).
Finally I come to the conclusion that the problem that causes the trouble was the SSD. So the suggestion of geit was correct:
This is nothing unusual and not a hardware failure. In the early days ide devices had many issues, when being used on the same IDE bus. It got better and better over the years, but never was perfect.
Especially the drives used in Apple devices are often problematic in this case. It also happens, when using SSDs in PowerBooks.
The original 80GB HDD works in both machines and CD drive is than not blocked, while with the SSD the CD drive was missing. For those how wants to avoid the same problems I use an "KINGSTON SSDNow KC380 120GB 1,8 microSATA3" together with an "Adaptare 46234 Adapter". Maybe it is this IDE 44 pin to Micro-SATA adapter that causes this problems with both MM.
Than just for luck I ordered an other SSD this time an "Transcend TS32GPSD330 interne SSD 32GB" that has direct an IDE 44 pin interface and not needs an adapter as my 1st SSD.
And what should I say? This SSD works perfect in both MM and not have any side effects to the CD drive.
