Step by step guide for installing WB3.1 on MorphOS.
    Cool_amigaN
    Posts: 746 from 2011/11/30
    Thanks for the prompt reply.
    I have commended the path of the harddisk in uaerc to correspond on my 3.9 (with whdload installed) drawer.
    If I just double the e-uae executable (as I have already described), I can boot into my 3.9 setup.
    However, if I point the conf path of uaeload to my uaerc, I get the error I described.
    Hope this helps.
  • »18.06.14 - 16:09
    Cool_amigaN
    Ok, I 've a similar thread here -> https://morph.zone/modules/newbb_plus/viewtopic.php?topic_id=6701&forum=9#75281 that describes more or less the same problem I face. I think I have understood the reason. Will try to find sometime later today to test it.
  • »18.06.14 - 16:17
    Cool_amigaN
    OK, I am really close now!
    Andreas was right; I had to point to my WHDload folder as a filystem on the E-UAE config file as well. Then I double clicked E-UAE executable, loaded Workbench 3.9, automounted my WHDload drawer games, opened Zool, double clicked the slave and it worked!
    That's the good news. The bad news is that if I double click the slave from iGame in Ambient I get the following error:
    UAE is not yet running or boots slow. Please use uae_rcli to your E_UAE system or try to increase uaeload timeout.
    Inceasing the timeout didn't had any effect.
    Still, I have copied uae_rcli to both MorphOS C: and to my 3.9 C:. Afterwards, I placed the following command to my startup-sequences (after LoadWB): Run >nil: C:uae_rcli
    As a matter of fact, here below is my Startup-Sequense on the emulatd side (note that I am using the lite version which came with uaeload):
    ; $VER: Startup-Sequence_Lite 1.0 (29.11.09)
    ; Startup-Sequence for lite E-UAE system under AmigaOS 3.9
    C:SetPatch QUIET NOROMUPDATE
    FailAt 21
    C:MakeDir RAM:T RAM:Clipboards RAM:ENV RAM:ENV/Sys
    C:Copy >NIL: ENVARC: RAM:ENV ALL NOREQ
    Resident >NIL: C:Assign PURE
    Resident >NIL: C:Execute PURE
    Assign >NIL: ENV: RAM:ENV
    Assign >NIL: T: RAM:T
    Assign >NIL: CLIPS: RAM:Clipboards
    Assign >NIL: REXX: S:
    Assign >NIL: PRINTERS: DEVS:Printers
    Assign >NIL: KEYMAPS: DEVS:Keymaps
    Assign >NIL: LOCALE: SYS:Locale
    Assign >NIL: LIBS: SYS:Classes ADD
    Assign >NIL: HELP: LOCALE:Help DEFER
    C:LoadMonDrvs
    SetEnv Language "english"
    SetEnv Workbench $Workbench
    SetEnv Kickstart $Kickstart
    UnSet Workbench
    UnSet Kickstart
    C:AddDataTypes REFRESH QUIET
    C:IPrefs
    C:ConClip
    Path >NIL: RAM: C: SYS:Utilities SYS:System S: SYS:Prefs SYS:Tools
    Resident Execute REMOVE
    Resident Assign REMOVE
    C:LoadWB
    EndCLI >NIL:
    And regarding MorphOS:S startup-sequence, looks like this:
    ; MorphOS startup-sequence
    ; Copyright © 2002-2012 The MorphOS Development Team, All Rights Reserved.
    ; This script is executed on system boot. Do *NOT* modify this file!
    ; Use S:user-startup instead.
    ; $VER: startup-sequence 1.12
    Failat 21
    Version >NIL:
    Resident >NIL: MOSSYS:C/Assign PURE
    Resident >NIL: MOSSYS:C/Execute PURE
    MakeDir RAM:T
    Assign T: RAM:T
    MakeDir >NIL: RAM:ENV RAM:Clipboards
    Copy >NIL: ENVARC: RAM:ENV ALL NOREQ DONTOVERWRITE
    Assign ENV: RAM:ENV
    if exists SYS:Locale NOREQ
    Assign LOCALE: SYS:Locale
    if exists SYS:Locale/Help NOREQ
    Assign HELP: SYS:Locale/Help
    endif
    endif
    if exists MOSSYS:Locale NOREQ
    Assign LOCALE: MOSSYS:Locale ADD
    if exists MOSSYS:Locale/Help NOREQ
    Assign HELP: MOSSYS:Locale/Help ADD
    endif
    endif
    Assign KEYMAPS: DEVS:Keymaps DEFER
    Assign CLIPS: RAM:Clipboards
    Assign PRINTERS: DEVS:Printers DEFER
    Assign REXX: S: DEFER
    Assign MUI: SYS:Applications/MUI DEFER
    LoadMonDrvs
    if exists "MOSSYS:Devs/DOSDrivers/CON" NOREQ
    Assign >NIL: CON: DISMOUNT
    endif
    Mount >NIL: MOSSYS:Devs/DOSDrivers/~(#?.info) DEVS:DOSDrivers/~(#?.info)
    UnSet Workbench
    UnSet Kickstart
    ConClip
    Path >NIL: C: SYS:Utilities S:
    IPrefs
    if not exists ENV:NOTRANCE NOREQ
    Run <>NIL: DETACH QUIET Trance
    endif
    RexxMast >NIL:
    Assign >NIL: TurboPrint: MOSSYS:TP
    if exists "TurboPrint:configs/_Last_" NOREQ
    Run <>NIL: TurboPrint:turbo/ttp
    endif
    AddAudioModes >NIL: REFRESH QUIET
    if not exists ENV:MorphOSSDK NOREQ
    if exists SYS:Development NOREQ
    SetEnv MorphOSSDK SYS:Development
    endif
    endif
    if exists ENV:MorphOSSDK NOREQ
    Assign SDK: "$MorphOSSDK"
    if exists SDK:Startup NOREQ
    Execute >NIL: SDK:Startup
    endif
    endif
    if exists S:User-Startup NOREQ
    Execute >NIL: S:User-Startup
    endif
    Resident >NIL: Execute REMOVE
    Resident >NIL: Assign REMOVE
    LoadWB
    run >nil: c:uae_rcli
    EndCLI >NIL:
    Again, what I am missing, here?
  • »18.06.14 - 22:18
    Posts: 2027 from 2003/2/24
    At least this:
    Anyway, you shouldn't try to use uae_rcli on MorphOS side. You only need it inside the E-UAE.
    I might try to install similar setup at some point later, can't help before looking better to those systems...
  • »19.06.14 - 10:49
    Cool_amigaN
    Well, I decide to go brave style and modify the startup sequence of MOSSYS: since I could find the startup sequence in SYS:s.
  • »19.06.14 - 12:55
    Jambalah
    Posts: 820 from 2008/3/30
    Bravery is ok but won't help here =)
    Check the paths again and be sure they correspond and/or there is any error. This happens when iGame doesn't find the right directory. After you are sure that no errors are present, open iGame dire and erase "gamelist" and "repos.prefs" files then launch program again and redo settings.
    Pegasos II 1 ghz
    Powermac G5 dual 2.0 ghz
    Powerbook G4 1.67 ghz 17
  • »19.06.14 - 14:10
    Cool_amigaN
    Are you sure that uae_rcli has anything to do with iGame prefs?
    Will check it of course later tonight but I have my doubts.
    Also, I have found a 4 month old similar thread herethat describes slowness of UAE when enabled (hint: uaeload complains also for slow boot).
  • »19.06.14 - 14:41
    Jambalah
    Yes it has. I tried to erase the line in s:startup-sequence invoking uae_rcli iGame will alert something is not going well and the whdgame won't start.
    Double click on the whdgame icon inside emulated workbench and the game run normally. So uae_rcli is necessary to iGame so to start whdgames using its gui.
    Pegasos II 1 ghz
  • »19.06.14 - 18:02
    Cool_amigaN
    I finally did it! uae_rcli under e-uae was not set with executeable flag. Now it works like a charm. Thanks everyone for the assistance!
  • »19.06.14 - 22:35
    Papiosaur
    Posts: 2047 from 2003/4/10
    WeiXing3D: it's a good idea, i could test that but i must buy AmigaForever before and for the moment i have not the money for that.
    Jambalah prepare a guide to install Workbench and Whdload for E-UAE:
    https://fbcdn-sphotos-d-a.akamaihd.net/hphotos-ak-xfp1/t1.0-9/10462770_10201148804562300_2498292179593362605_n.jpg
  • »20.06.14 - 22:00
    Posts: 72 from 2013/7/25
    I've mostly got rhlaunch working under UAE, the only issue I have is that on some games I get the following error:
    I'm tipping I need some form of backup KS1.3 rom loaded for certain games, however I have no idea how to do so, any advice?
    Cool_amigaN, is it possible for you to post a step by step updated guide of what you have done just in case others want to do the same?
    The more detailed information we have, the better.
    [ Edited by madCrow 22.06.2014 - 06:07 ]
  • »21.06.14 - 23:05
    Sorry jPV,
    I already know I need to use a different version of kickstart, my issue is how do I implement differing KS versions in UAE? Is it possible, for example, to have a backup KS for the software that needs it?
  • »23.06.14 - 07:01
    Your problem was that you need different kickstart images for WHDLoad, not for UAE. You need those kickstart images in your Amiga setup where WHDLoad can look them for the games which need those. Read the WHDLoad docs how to have several different versions available and how to name them.
    Having different kickstarts for UAE won't help you here. But if you want those too, it's possible to make different config files and provide them to UAE when starting it. Can't check just now what was the option, but -f or something. But as said, this won't help the problem you described which is purely just WHDLoad issue.
  • »23.06.14 - 18:20
    Thanks jPV, copied all the nessecary ROMS and relocation files to the emulated A1200 and renamed the files accordingly and everything is working perfectly!
    Once again, thank you very much for your time (and patience).
    Now to install iGame.
  • »24.06.14 - 03:56
    One more question...
    Is it possible to configure E-UAE so that the mouse pointer stays within the confines of the emulation screen? As when the mouse pointer hits either the left or right hand side edges another mouse pointer that goes outside the emulation screen and makes things very confusing.
    Also, how can I make my desktop look prettier? The standard WB3.1 is a little bland and lacking in color.
    [ Edited by madCrow 24.06.2014 - 14:05 ]
  • »24.06.14 - 04:41
    Cool_amigaN
    @madCrow
    There are lots of Workbench (3.x) enhancing packs available: From AmigaSYS (my old time favorite) to ClassicWB and ofc the most notable AmiKit.
    However, the more you skin/edit/add third party programs to the default environment, the more bloatware it gets (emulation gets "heavier", more cpu cycles are needed etc).
    Frankly, the only reason I need 3.x is to boot straight to WHDload. If that's the case for you as well, then I suggest to have the more stripped version of classic AOS as possible.
  • »24.06.14 - 12:54
    Waitsnake
    Posts: 26 from 2014/7/21
    I'm Waitsnake from Germany and I'm new to MOS and hope to learn a bit more about this operating system family and also amiga systems. As kid I start with C64 and than unfortunately go direct to PC (Win & Linux) and later to Mac and I miss all the Amiga stuff. ;-(
    As mentioned in this topic before I also tried to install iGame, UAELoad, WHDLoad, E-UAE with WB 3.1 and so forth according to an manual I found here: E-UAE_installation_on_MorphOS.
    I use MOS 3.6 with Chrysalis pack 3.6.1 beta installed. It comes with E-UAE 0.8.29-WIP4 from 01.07.2014.
    I had the same issues that WB 3.1 was not able to install when using as virtual hard disk a directory from MOS (filesystem2=rw,DH0:System:HardDisks/W orkbench,1) and it allways seems to hangup the complete emulation at around 12% of install progress when the installer start to create folders and icons on the file system.
    In the logfile I saw some strange error messages that seems to correlate with the problem: „FILESYS: UNKNOWN PACKET 1f".
    I try to look for the source code to find this error message. I only could found the source code of an older version (0.8.28) linked to this page here: www.amigaforever.com.
    In the file filesys.c You see that 0x1f=31 is defined as ACTION_INHIBIT and the big switch inside the function handle_packet() does not handle this type and the switch will run into the default-case that only returns false and print this error message.
    In the file history the author even mentioned: „Known limitations: * Does not support ACTION_INHIBIT (big deal).“. So that seems an important issue of E-UAE anyway.
    Than I found some more information about that ACTION_INHIBIT here: Amiga DOS packets (see at "dos.library/ACTION_INHIBIT" ). It seems to be an kind of flush action that writes all file buffers to hard disc when requested, like the sync command in Linux systems.
    With a google search I found the source code of fs-uae. Inside the winuaechangelog.txt you found that they implement this ACTION_INHIBIT with Beta 1 and with Beta 2 they fix some infinite loop that this function causes.
    Well I really don't know much about that filesystem stuff and I'm not sure if the missing implementation of ACTION_INHIBIT in the E-UAE of MOS really causes the hangup of the emulation. I just hope that someone with more knowledge will pay a bit attention on it and take a look if it is a issue or not.
    The source code of ACTION_INHIBIT in FS-UAE can be found here: filesys.cpp
    A good workaround of this problem is to avoid file system access and use a hardfile (hdf) instead of that. Unfortunely file system is needed to connect iGame in MOS to the games installed in E-UAE.
    [ Edited by Waitsnake 21.07.2014 - 21:56 ]
  • »21.07.14 - 23:50
    Jambalah
    Hi Waitsnake and welcome!
    Your error occours when you try install Workbench 3.1 directly from Ambient. If you perform the same action inside E-UAE installation goes flawless. You can create Workbench and Games directories directly from Ambient but you have to install Workbench using E-UAE emulation.
    Inside the guide read page 22, from line 1 to 7: if you are using iGame launcher you can use a hardfile (hdf) with virtual hard disk (filesystem) provided that both are "2". So you can have: hardfile2= and filesystem2=. In fact usingiGame launcher you must use virtual hard disk only to store WHDLoad games while Workbench can be installed inside a hardfile.
    Edit:
    sorry Waitsnake, I was reading your post again: you wrote that emulation hangs at 12%. So , does this problem happen when you are installing Workbench 3.1 after you have started E-UAE?
    [ Edited by Jambalah 22.07.2014 - 19:48 ]
    Pegasos II 1 ghz
  • »22.07.14 - 20:40
    Waitsnake
    Hi Jambalah,
    thanks for your answer and sorry. I guess I miss the point in my last post.
    1.) I tried to install WB 3.1 in E-UAE on MOS and I was using filesystem2 to mount directories from MOS into E-UAE (for System and Games).
    I tried the installation a couple of times and always at 12% the complete emulation hangs, well even the MOS hangs more or less (windows moving around still reacts, but any other action hangs as well). I take a closer look at installation and see that first 11% of installation do nothing else than interact with user. The copy of files and directories just starts at 12% and this is the moment when E-UAE hangs.
    2.) I just boot from a WB 3.1 start diskette and try only try to copy 1 or 2 files (e.g. the calculator app or something else) from the start diskette to the folders mounted by filesystem2. Sometimes the copy works. But more often this simple file copy also hangs up the E-UAE. So problem is not the WB 3.1 installer itself but it seems to be an issue of E-UAE when using the feature of filesystem2 and copy any file to it.
    In both cases I see these „FILESYS: UNKNOWN PACKET 1f" error messages in E-UAE console output at the time of first file access to an filesystem2 mounted device. So I was thinking something could be wrong with E-UAE and I was hoping one of the developers of this software is active in this forum and he could take an eye on it. As I mentioned in my last post I was guessing the issue of E-UAE seems to be related to that missing implementation of the ACTION_INHIBIT feature from Amiga DOS.
    3.) I was creating an empty hardfile on an other operating system and than use this file with the hardfile2 feature of E-UAE and than I could install WB 3.1 without any problem. So the issue is only related to filesystem2 and hardfile2 works a treat.
    Problem I see in future with this workaround of 3.) is that even if I have now a working WB 3.1 installation using hardfile2 I still need the filesystem2 for the game folder that bridges iGame application on MOS with WB 3.1 on E-UAE. And I saw in 2.) that any simple write access from WB 3.1 to an filesystem2 mounted device could lead to an hangup and this could really ruin your day.
  • »22.07.14 - 22:15
    Daff
    Posts: 242 from 2003/4/5
    @Waitsnake
    "always at 12% the complete emulation hangs, well even the MOS hangs more or less"
    "FILESYS: UNKNOWN PACKET 1f"
    Same for me in my E-UAE setup with AmigaOS 3.0. Copying files hangs the system.
    But, strangly, it works with E-UAE/AmigaOS 3.9, no hangs, no "unknown packet" messages, etc.
    I remember a user had the same problem on AmigaOS 4.1 (I read this on AmigaWorld or Amigans some weeks ago).
    http://obligement.free.fr
  • »23.07.14 - 07:32
    Cool_amigaN
    Anyone can comment on the above, please?
  • »23.07.14 - 08:48
    Jambalah
    I've created two new empty directories to use as virtual hard disk partitions to perform a Workbench 3.1 installation (I did the same when I was writing the guide, see snapshots) and... it doesn't work anymore... I have the same problem above mentioned during installation which stops at 12% while installer is copyng WBStartup.info inside hard disk. How is it possible? I'm using the same adf images I used before and I tried Wb installation on the 3.5 too (I haven't upgraded MorphOS on my MDD yet). I've tried with filesystem and filesystem2 and always failed. I'm really disappointed...
    Pegasos II 1 ghz
  • »23.07.14 - 15:21
    Jambalah
    After some days of tests I discovered that I can't install both Workbench 3.0 and 3.1 if I use E-UAE-0.8.29-WIP3 and WIP4. This morning I tried with E-UAE-0.8.28-2 and all went flawless trying to install WB3.0 and WB 3.1 (I've performed installation of both system three times with no problems). The FILESYS: UNKNOWN PACKET 1f error (if this is an error) was always prompted but installations always went ok. So I ask to Waitsnake and Papiosaur and all people that want to give a try to repeat what I tested so to confirm that all works with this E-UAE version.
    I will try with E-UAE-0.8.29-PPCJIT_BETA03_MORPHOS next so to make a complete test.
    Pegasos II 1 ghz
  • »25.07.14 - 09:13
