Muchmore? how to get it to work?
    osco
    Posts: 680 from 2009/10/20
    Have legacy software with docs that tool with Muchmore?
    TIA
    [ Edited by osco on 2010/6/26 19:07 ]
  • »25.06.10 - 23:16
    stephen_robinson
    Posts: 746 from 2007/4/22
    I think I speak for many when I ask, Wut?
  • »26.06.10 - 04:30
    analogkid
    Posts: 722 from 2004/11/3
    Maybe it's the best idea to select another textviewer... If you don't like Multiview or the internal Ambient-Viewer, you could also select something from Aminet like Next 3.9 or TextView.
  • »26.06.10 - 04:39
    Golem
    Posts: 766 from 2003/2/28
    Just open icon information and change the default tool.
  • »26.06.10 - 05:18
    amyren
    Posts: 219 from 2010/5/15
    muchmore works on morphos as well. At least it works here on MOS2.5 / Mac Mini.
    If you have many files using this tool, you could just copy the muchmore program file to sys:c
    I had several copies of the file on my wb31 installation, so I guess many archives have the file included in their distribution.
  • »26.06.10 - 09:01
    Kind of scary since the OP was written by someone who "supposedly" lives in a country where English is the native language.  :lol:
  • »26.06.10 - 16:11
    Golem
    Always makes it easier if you get the terminology right, and that space between much and more didn't exactly make it easier to guess.
  • »26.06.10 - 16:30
    osco
    I apologize to all but to me all MORPHS are genius' and telepathic as well.  :-D
  • »26.06.10 - 20:10
    Posts: 12558 from 2003/5/22
    Definitely.
    http://aminet.net/search?content=muchmore
  • »26.06.10 - 20:41
