MOS 1.4.4 and AmiBlitz and NewsCoaster
    Velcro_SP
    Posts: 929 from 2003/7/13
    I installed MOS 1.4.4 yesterday with the smart installer on the CD and it seemed to go like it was supposed to. When I rebooted off hard-drive there weren't any obvious visible changes, but I understand 1.4.4 is not that kind of update.
    So okay fine. I am still happy to get an update with bugfixes and minor improvements and all that.
    I tried to run AmiBlitz and it now seems to run better. It still ain't working right but it's closer to useable in MOS 1.4.4. Another AmiBlitz site.
    But then I tried the great NewsCoaster. But NewsCoaster won't run now! It ran grrrrreat before!
    I am interested to know if anyone is running NewsCoaster under 1.4.4 and what my problem might be. I would also like to hear your experiences with AmiBlitz on MOS if anyone is into that.
    Pegasos2 G3, 512 megs RAM
  • »03.04.05 - 10:32
    marcik
    Posts: 268 from 2003/4/12
    About NewsCoaster - just gueesing but maybe it require new version of NList/NListtree? 1.4.4 comes with the same version like 1.4, but since 1.4 times new version was released.
  • »03.04.05 - 10:52
    Velcro_SP
    Where should I get Nlist and Nlisttree then? I don't see new ones on Aminet.
  • »03.04.05 - 11:14
    Robin
    Posts: 741 from 2003/2/24
    Not sure, but you could try this http://sourceforge.net/projects/nlist-classes
  • »03.04.05 - 11:46
    marcik
    If you had installed them on you old MorphOS, then sys:MorphOS-old/classes/mui
  • »03.04.05 - 11:50
    Velcro_SP
    Marcik, I really thought all that copying of MUI classes and stuff happened automatically.
    Anyhow, I downloaded and installed the latest Nlist archive from sourceforge.org, no luck.
  • »03.04.05 - 12:37
    Posts: 1932 from 2003/10/19
    Velcro I just downloaded newscoaster and its working fine for me under
    1.4.4, you may want to install it again and see if thats it. I got the
    latest version off sourceforce.
  • »03.04.05 - 13:36
