Amigift...
    Sphinx_Ra
    Posts: 276 from 2003/3/14
    Hello...
    GREAT ! :-)
    Amigift for Morpos :-D
    Anybody tryd it yet ??
    I have trouble with the Install script,
    it locks on MUI assign or something ?! :-(
    I tryd just to load the program, that works,
    but then i get a eror" can't start the daemon" :-(
    Anybody know to do this ???
  • »03.10.04 - 17:57
    Posts: 1087 from 2003/3/24
    I've made an MUI Assign in Ram:T, but the script stops in line 136 with Unable to locate a file or drawer!
  • »03.10.04 - 20:04
    Posts: 62 from 2004/9/8
    Hello,
    Amigift is not just for AOS3.9 ???
    Do you have tested bourriquet0.2.5 or mldonkey ???
    PegasosII G4 512Mo 80Go ATI RADEON 9200SE....
    Yeah! The best it's MorphOS :)
  • »04.10.04 - 01:59
    naTmeg
    Posts: 135 from 2004/2/8
    @ThePlayer
    You need to create RAM:T/libs and assign MUI: RAM:T
  • »04.10.04 - 05:37
    Furvert
    Posts: 83 from 2004/4/20
    There is a very simple solution to this.
    You need to make two directories and a temp assign.
    In boot0:classes/MUI make a directory called libs
    inside this directory make one called mui
    These are the directories that so many installers are looking for.
    When you run install they usually ask for an assign for mui.
    Make the assign boot0:classes/mui This is temporary.
    The script will run normally from there.
    Once done, move the files to boot0:classes/MUI/
    and have fun :)
  • »04.10.04 - 08:45
    Sphinx_Ra
    @Furvert
    Cool... thx :-D
    I had indeed troubles with installers that
    where looking for these assigns :-(
    Finnaly problem solved :-D
  • »04.10.04 - 11:13
    Sphinx_Ra
    Hmmm...
    Program starts now...
    But it says in window "Running the Deamon, please wait..."
    Well... i'm now waitng almost 10 minutes :lol:
    It says in readme file:
    Compatible with MorphOS and AmigaOS4 hmm...
    Think i'm gonna male the author then...:-)
  • »04.10.04 - 11:38
    Posts: 47 from 2004/4/11
    >please wait..."
    R T F M
    Bye
    TriMa
  • »04.10.04 - 13:57
    Sphinx_Ra
    @TriMA
    I read the Readme :)
    It just strange, a few hours it did loaded the deamon, and did get the chance to
    go further with searching files but then i get this...
    http://members.chello.nl/e.poldervaart1/Amigift.jpg
    And just a few minutes ago, i get the same again..
    "blablabla , Plz wait"
    Oh, so you have it working then ???
  • »04.10.04 - 16:58
    Miky060
    Posts: 694 from 2003/2/24
    @Sphinx_Ra
    I get the same. Have you showed that grab to the author?
  • »04.10.04 - 17:20
    Sphinx_Ra
    @Miky666
    Yes, i did :-)
    I will PM you ;-)
    Don't think it's smart to copy/paste the e-mail reply here :-D
  • »04.10.04 - 18:05
    realstar
    Posts: 298 from 2003/2/24
    I have AmiGift working ok on MorphOS right now,
    first you need to open the file "local/gift.conf"
    and change value of setup to "setup = 1".
    After this I encountered an error message
    when searching which has to do with some
    experimental aminet support. I had to make
    a directory in Daemon/local called "aminet"
    and copy the config file into there, it is
    working good on my PegII now. :)
    You can try this fix from a shell:
    makedir AMIGIFT:daemon/local/Aminet
    echo "" >AMIGIFT:daemon/local/Aminet/Aminet.conf
    Or get an aminet config file here:
    http://xoomer.virgilio.it/cieffeeditingvideo/docs/
  • »05.10.04 - 01:17
    maurensen
    Posts: 358 from 2003/10/3
    I've also settind AMIGIFT like said but I get a request asking me to
    assign gift:
    It seems the daemon is connected but i get 0 entries when I make a
    query...
    Any guess??
  • »04.11.04 - 18:00
    Posts: 918 from 2004/1/24
    Hmpf, I can't even load the bloody program. I've tried a manual
    nistall and the suggested install as described here, but everytime
    when i load gIFTmui it pops an error req, telling me it can't find
    the lamp.mui class and the amigift.library, though I have them both
    installed. Suggestions anyone?
  • »04.11.04 - 18:27
    Druideck
    Posts: 82 from 2003/5/6
    I have Amigift and MLdonkey working on
    my Peg 1. I used Realstars suggestions
    listed in this forum. I also had trouble
    with lamp and other MUI classes.
    Maybe certain versions work better?
    OR i was missing something in MUI.
    I would be more specific if I could, sorry.
  • »05.11.04 - 02:43
    Druideck
    I had the same trouble with the daemon
    until i set my sharing path in settings
    and saved,then restarted the program. The daemon
    pops up to reread the share drawer every
    once in awhile, but only for a few seconds.
    Amigift takes a little tweaking but
    is working pretty good now. I even got
    a connect to gnutella.
  • »05.11.04 - 02:50
    amigift works here...
    OpenFT is ok but the research gives no results... :(
  • »05.11.04 - 03:57
    yeah!! Now... I have downloaded 3 files in OpenFT network...
    I'm happy.. :)
    Amigift, Bourriquet, MLDonkey... P2P is ok for MorphOS
  • »05.11.04 - 04:22
