Sharing swap partition possible ?
    Brumiga
    Posts: 274 from 2004/4/3
    Hello guys,
    I read on a pc magazine that is possible to share the same partition for swap both on linux and windows. Could it be possible to do the same between a linux distribution and morphos ? I have heard that morphos 1.5 would give us virtual memory, so a swap partition will be required for this.
    Brumiga
  • »19.10.04 - 17:30
    magnetic
    Posts: 2129 from 2003/3/1
    Tokai
    That is correct My peg runs with 2 Linux installs sharing swap as are the Open Desktop Workstations! :-)
    @Brumiga
    Where did you hear the next MOS update will have Virtual Memory and a swap partition?
    magnetic
    [ Edited by magnetic on 2004/10/20 18:52 ]
  • »20.10.04 - 20:51
    Posts: 408 from 2004/7/15
    Can windows use partition instead of file for swap? How? I'd like to get rid of swap file - the primary source of FS corruption!
    Brumiga
    1. Firstly let's get 1.5 release and only then speak :-D
    2. Do you really need swap for MorphOS? Why? Are you planning to read whole DVDs to memory?
    iPod, iBook, iMac,... iRobot?
  • »21.10.04 - 06:17
    Posts: 979 from 2003/6/28
    If MorphOS 1.5 supports virtual memory, doing a FS driver for read linux swap partitions will can help a lot in that, so if you like that, start coding it!
  • »21.10.04 - 15:50
