Perfect Paint
    Motosampy
    Posts: 199 from 2004/8/14
    Has anyone got Perfect Paint running without problems under MOS ? Freezes here always at selecting new image size (when creating a new image)...
    - Sami
  • »17.09.04 - 16:33
    Aaron
    Posts: 127 from 2003/6/14
    Motosampy,
    Unfortunately, the only way to run PfPaint on MOS is through UAE.
    PfPaint will not run on MOS.
    Even worse, there hasn't been an update to PfPaint in over a year and
    the website hasn't been updated in over a year also. It looks like
    development has stopped.
    --Aaron
    --Aaron Diezman
  • »17.09.04 - 18:16
    Motosampy
    Darn, I really love the program.... Well, need to check the other drawing utilities, if there were one I enjoy to use...
  • »17.09.04 - 18:56
    Toto
    Posts: 268 from 2003/4/20
    Hi Motosampy,
    Why don't you try TVPaint, it's a really great paint program and works wel in MOS.
    -Toto
  • »17.09.04 - 19:14
    Motosampy
    Where can download it? (If it's commercial would like to try a demo first)
  • »21.09.04 - 18:54
    Posts: 154 from 2003/4/22
    Hello !
    TVPaint is now free and can be download here: http://ariko.free.fr/amiga/tvpaint/tvpaint.html
    Bye
    MorphOS Rulez !
  • »21.09.04 - 19:03
    Motosampy
    Downloaded TVPaint.... Installer does nothing, the program seems to run without any installation though, but asks for serial number... Web site is in French (can't any French except "Oui" and "No") and the guide has no information (or I just can't find any...) Someone help me, please!
    Okay, found the serial code !
    [ Edited by Motosampy on 2004/9/22 21:45 ]
  • »22.09.04 - 16:31
    Jupp3
    Posts: 1193 from 2003/2/24
    Watch out when switching screens when running TVPaint, it might get really confused...
    Personally I use:
    TVPaint, ImageFX, fxpaint and Imagestudio.
    Photogenics also works very well.
    Deluxe Paint and Personal Paint both work, but both have many problems when running on morphos...
  • »22.09.04 - 17:38
    Posts: 979 from 2003/6/28
    What about Perfect Paint for MorphOS? ;-)
  • »24.09.04 - 04:07
    Phantom
    Posts: 381 from 2004/9/7
    I recently downloaded TVPaint and the serial code, but the archive had only the program (no installer). I run it, I choose the resolution screen but then nothing happens (it returns me to ambient screen).
  • »06.10.04 - 22:35
    Tcheko
    Posts: 544 from 2003/2/25
    TV paint need special font IIRC.
    Copy TVPaint font dir to fonts:
    It shalls work after.
    Czk.
  • »07.10.04 - 05:47
