Hollywood 1.9/Sound-datatype
    GMKai
    Posts: 259 from 2003/4/7
    I must say Hollywood 1.9 is really nice, it is fast an capable to do a lot of things.
    But one little glitch with my system is here. It must be related with my installed datatypes.
    Please can anyone check what working datatypes are there for soundoutput of iff-files.
    testing could be done with applause.iff from the puzzle example.
    this file doesn't play with multiview either.
  • »22.04.04 - 17:12
    Krashan
    Posts: 1107 from 2003/6/11
    Please send me the problematic file via e-mail
    (krashan@teleinfo.pb.bialystok.pl). Also please report sound.datatype
    version and 8svx.datatype version.
  • »23.04.04 - 04:13
    GMKai
    now i have installed sound-datatype from Stephan Rupprecht, sounddt v41, i think.
    now it works
  • »23.04.04 - 06:43
    GMKai
    what would be the latest native versions of the sound- and svx-dt???
  • »26.04.04 - 14:02
    Posts: 979 from 2003/6/28
    What if gives you problems? Please say where download it...
  • »07.09.04 - 05:08
    Posts: 918 from 2004/1/24
    @GMKai
    Try this link: https://morph.zone/modules/mydownloads/visit.php?lid=165
    It's the "unofficial update of MorphOS sound datatypes.
    This is the second update. The update is a replacement of the first one and can be installed both over previous update or on clean MOS 1.4.
    The second update adds proper MPEG2 recognition and handling, also fixes problems with MPEG1 Layer II files. See ChangeLog for complete list of changes."
  • »07.09.04 - 06:33
