To switch off debugging on serial port, you have to boot MOS with ramdebug option. Goto BIOS and type "setenv boot-file boot.img ramdebug"
I also noticed that I have to switch on modem _after_ booting MOS. Otherwise it cannot be initialized.
@pOS
Thanks for the info! Oddly enough, I didn't actually try to turn off my modem (duh) to avoid the problem!
Assuming I get through the above, what *is* the correct device name and unit number to select for the Peg's serial port?!? Since the Peg should be using a modern UART chip, I trust all those serial port booster device files from the past are obsolete.
