very big jpeg picture not shown/loaded
    Brumiga
    Posts: 276 from 2004/4/3
    hello,
    i can not on my standard Pegasos 2 display with MysticView or load with FxPaintLite this very big picture, 9372 x 9372 in 24 bits, from Aminet Set 12 cd 47, wtc-photo.jpg. the 2 programs says that there is not enough memory. my computer has 256 mb ddr memory and my gfx card is Radeon9200SE. but on my amiga 1200 aga, 1260 turboboard 64 mhz 64 m memory, Visage 39.22 can show it. it takes 2 minutes but it can. i use normal picture.datatype with jfif.datatype 44.7 of Gunther Nikl and the assign JPEGTMP: to T:. what/where is the problem whith the Pegasos 2 ?
    Brumiga
  • »13.04.04 - 17:05
    warface
    Posts: 653 from 2003/2/24
    If I'm not mistaken Visage uses it's own jpeg decode algorhytms, and not the datatype system.
    If my calculations are correct: it occupies 85 Mb in ham8 - impossible that you can display it on a stock 1200 with 2 Mb chip ram with datatypes. Or with 8 Mb gfx ram.
    In 24 bit it occupies 257 Mb. That simply won't fit. See the problem?
    The picture is BIG. Maybe some custom picture viewer can show it to you.
  • »13.04.04 - 17:25
    Posts: 979 from 2003/6/28
    Yes, i has these problems too, and are very anonying, will can be solved soon?
  • »13.04.04 - 17:45
    Robin
    Posts: 741 from 2003/2/24
    PicShow,Multiview and fxPaint load the picture
    fine here ... 9200/64MB, 512MB, Peg II/G4
    I was surpised to find the cd still wrapped ;)
    Guess thats why I've never seen this photo before ...
  • »13.04.04 - 18:18
    Robin
  • »13.04.04 - 18:23
    Oppressor
    Posts: 13 from 2004/3/18
    The problem with MysticView is even worse than that; the picture will be copied from a datatypes object to a buffer of its own. If I calculate correctly, this would sum up to a peak memory consumption of at least 600mb. I'd suggest to find a better tool for that purpose, as I'm not going to enhance MystiView anymore. It does well what it does, but I think it's conceptually outdated now.
  • »14.04.04 - 01:11
    Jupp3
    Posts: 1193 from 2003/2/24
    I think Visage can scale images while loading them to fit the screen... That should lower memory requirements...
  • »14.04.04 - 03:01
    warface
    It's the way the datatypes system works. Don't know if it will change, but Visage didn't use datatypes for the picture. Add to that, Visage scales it down, and even if not, in ham8 you have to deal with third the size of the original.
    In it's real size it just won't fit, as it's enermous. Use software which has been designed to be capable to handle such large images, like ImageFX, etc.
  • »14.04.04 - 05:30
    DethKnight
    Posts: 139 from 2003/6/24
    viewed it in GiMP here.
    thatsa big pic , there must be a purpose to it being that large
    I am ; therefore you are
  • »14.04.04 - 05:44
