Posts: 2591 from 2003/4/10
I have downloaded the iso (very slow...)
You must edit this file:
sys:wbstartup/crabum.rexx
at line 124, add a ' character at the beginning of the line then save and reboot.
Sorry for this error, there is no problem with the french version of the menu.
I have a bizarre problem with the installation script, it doesn't delete this file :
sys:wbstartup/crabum.rexx_fr
and i understand why, somebody has an idea ?
You can delete manually too.
[ Edité par Papiosaur 24.11.2014 - 23:32 ]
