Camera driver/software
    droopy
    Posts: 35 from 2013/12/12
    Hi
    Does anyone have tips about some generic camera software to use with a chinese endoscope camera(usb) ?
    I have it working under windows without any driver disk.
    Or if someone have ideas on how to get it to work with MOS.
  • »03.08.14 - 12:13
    pegasos-sigi2
    Posts: 265 from 2006/8/31
    We need more info about this cam. Weblink of this cam ?
  • »03.08.14 - 12:56
    Posts: 1076 from 2004/9/23
    It cannot work until usb supports iso transfers.
    Geit
  • »03.08.14 - 13:01
    droopy
    it is one like this.
    http://www.ebay.com/itm/2-5-7-10-15M-6LED-USB-Waterproof-Endoscope-Borescope-Snake-Inspection-Camera-7mm-/301198004961?pt=LH_DefaultDomain_0&var=&hash=item4620ccd2e1
  • »03.08.14 - 14:29
    pegasos-sigi2
    Geit
    You say it !
    A more extensive doc: http://en.wikipedia.org/wiki/USB_video_device_class
  • »03.08.14 - 14:53
    droopy
    I don't really know what you are trying to say with the abowe. I try to explain myself a bit.
    Poseidon USB is understanding I connect a webcam to MOS and light gos on. That's it sofaar.
    What I aare asking is IF there is any kind of webcam software I can try to install to make the camera work as any webcam ? Displaying it's content on My screen, it dont have to be able to send any footage or stream. Just show it on a local screen.
    Or are you saying that there is no possibility to use a webcam with morph os ?
  • »04.08.14 - 09:13
    No, there is no way to use an usb webcam with MorphOS right now.
    There are some (very old) webcams which are supported, but only for stills.
    USB will detect *all* kind of devices. Supported or not. That´s how usb works.
    Geit
  • »04.08.14 - 12:11
