site doesn't load
    amiga4001
    Posts: 454 from 2006/11/16
    Can anybody acces http://www.conrad.com ?
    It tries to load but that's all.
    I am on owb 1.2 and mos 3.2.
    I was able to acces it before with older versions of mos and owb but maybe the site has changed?
  • »05.06.13 - 18:55
    Posts: 12543 from 2003/5/22
    > Can anybody acces http://www.conrad.com ? It tries to load but that's all. I am
    > on owb 1.2 and mos 3.2. I was able to acces it before with older versions of
    Same here, also with MorphOS 3.2. And it's the case with other browsers on MorphOS 3.2 as well, so is most likely because of the new Netstack rather than OWB. (That's assuming you are using the recent OWB 1.20, not the 4 year old OWB 1.2.)
  • »05.06.13 - 19:13
    Krashan
    Posts: 1107 from 2003/6/11
    The site is also unreachable with any of MorphOS HTTP downloaders (tried three), it confirms Andreas conclusions.
  • »06.06.13 - 02:09
    amiga4001
    Ok thanks for trying.
    Hope there will be a fix soon.
  • »06.06.13 - 02:57
    catohagen
    Posts: 297 from 2003/5/20
    maybe its a new site....netstack doesnt always work with post-90' internet  :-D  :-D
  • »06.06.13 - 03:28
    Ingo
    Posts: 103 from 2004/3/19
    I can't even ping the site.
  • »06.06.13 - 16:27
    amiga4001
    Will changing to roadshow help btw?
    Can anybody try?
  • »06.06.13 - 19:21
    weiseb
    Posts: 215 from 2003/3/29
    Not sure about Roadshow on Morphos but the site loads on OS4
  • »07.06.13 - 04:02
    Nadir
    Posts: 178 from 2003/3/17
    Do you have any basis claiming? The new stack core is really a lot newer than the old one and also newer than either roadshow or miami.
    The new code can of course have introduced some bug but in my opinion, it is more likely to be an issue on the other side of the connection as tcpdump shows a corrupted IP header. It might be some old/broken stuff that only worked by coincidence in old stacks or because of workarounds in new stacks on other platforms. I am not sure and not very keen to look closer into it right now...
    btw, there are also a number of sites that work now but were broken with old netstack
  • »07.06.13 - 09:04
    Would you please answer my question from the other thread? Thanks in advance.
    https://morph.zone/modules/newbb_plus/viewtopic.php?forum=11&topic_id=8914&start=44
  • »07.06.13 - 09:13
    catohagen
    it was a bad joke, sorry
  • »07.06.13 - 09:32
    defender
    Posts: 249 from 2011/4/24
    Do we have any updates to the "conrad.de" problem.
    I tried to buy a view things and put them in my shoping bag on a tablet-pc.
    This does not feel well, so I switched back to Morphos 3.4 an OWB 1.23.
    OK, I ended up here. Any clues ?
    Roadshow maybe ? some little adjustments ? MTU ? or what so ever ?
    greets
  • »03.01.14 - 19:20
    defender
    A simple way is to enable the http Proxy of your internet provider
    for me this is www-proxy.t-online.de port 80.
    An option to use this only for marked sites would be fine.
    But not so importent.
    greets
  • »05.01.14 - 17:16
