SimpleCalculator
    Posts: 848 from 2007/10/23
    Hotkey? Simply get the digits.
    If you have a PowerBook without numeric keyboard, you have to use the main keyboard.
  • »16.11.24 - 22:06
    Tcheko
    Posts: 544 from 2003/2/25
    Papiosaur wrote:
    get the digit?
    sorry, i'm a newbie in C and MUI...
    You want to grab numeric keystrokes?
    There is many ways to achieve that.
    Probably, the easier is doing a custom mui group class at the root of your mui object tree and setup some MUI event handler for grabbing ICMP_RAWKEY events.
    Then, from that subclass, you can check if numeric keys has been hit and do whatever processing you like with inside the MUIM_HandleEvent method.
    If you're doing something with the keyboard event and you don't want other objects in the object MUI tree to react to that event, you can instruct MUI to 'eat' the event (ie: kind of discard) by returning MUI_EventHandlerRC_Eat in the MUIM_HandleEvent method.
    For succeeding with all that, you first need to master MUI subclassing concepts. Best is probably reading some obligement article on the matter, for example:
    http://obligement.free.fr/articles/mui_custom_class.php
    Keywords: MUI subclass, MUIM_Window_AddEventHandler, MUI_EventHandlerRC_Eat
  • »17.11.24 - 08:28
    Posts: 2581 from 2003/2/24
    The question is why IDCMP_RAWKEY and/or specific NumPad keys?
    Why should it matter which 123....-+/= etc I hit?
    Just listen to IDCMP_VANILLAKEY and be done with it.
  • »17.11.24 - 09:14
    igracki
    Posts: 471 from 2003/2/24
    If you only need some few shortcuts you can use
    MUIA_Window_InputEvent
  • »17.11.24 - 13:14
