Graphic problems with some software
    Papiosaur
    Posts: 2607 from 2003/4/10
    Hello,
    i see some graphics problems with some software:
    - ControllerMap (include in SDL2/Extras/)
    - Some Templario software have a graphic ploblem with alpha color on 16bit screens
    - Graphic bug in InslandsMiniGolf (Intro menu)
    Others guys have these problems?
    Any ideas about the origin about these problems?
    Thanks
  • »06.08.24 - 09:01
  • ghh
    ghh
    Posts: 60 from 2017/7/15
    Controllermap. Latest SDL2 library.
  • »06.08.24 - 09:31
    beworld
    Posts: 683 from 2010/2/10
    I check that, thanks
    My MOS ports
  • »06.08.24 - 16:42
  • ghh
    ghh
    Controllermap will only fail if the joypad/joystick is not connected.
    With sdl2.library 3.11 (SDL_2.26.5_Libraries) it works even without a connected joy.
  • »06.08.24 - 18:55
    Templario
    Posts: 560 from 2012/4/28
    Papiosaur escribió:
    Hello,
    Thanks
    In my case this is because Hollywood isn't support screen depth of 16 bits.
  • »07.08.24 - 09:05
    beworld
    Yes i see that... i think i put a little fix for that on version 2.26.5 and missing to keep on new version... pfff
    My MOS ports
  • »07.08.24 - 09:47
