MorphOS SDK 3.14 and GCC9
  • MDW
    MDW
    Posts: 498 from 2003/7/25
    Hello
    I use FlowStudio with GCC5. However after release MorphOS 3.13 I decided to download new SDK (3.14) and switch to GCC9. Unfortunately when I try to compile my project with GCC9 I have message:
    ### Build Start ###
    make: Entering directory `/Files/MDW/dev/MyProject'
    mkdir: missing operand
    Try 'mkdir --help' for more information.
    make: *** [MKDIR_RELEASE] Error 1
    make: Leaving directory `/Files/MDW/dev/MyProject'
    ### Build End ###
    If I switch to GCC8, everything is ok, project is compiled and linked with success, executable file is ok.
    Where is the problem? Makefile generated by FlowStudio uses mkdir but... it looks ok. Why if I use GCC8 everything is ok?
    I noticed, if I set in Project Setings "g++-8", next to cycle gadget I see (shaded) "ppc-morphos-g++-8". If I set "g++-5", I see "ppc-morphos-g++-5", etc... However if I set "g++-9", the shaded label is empty.
    It is strange because I have GG:bin/ppc-morphos-g++-9.
  • »08.02.20 - 16:49
    Flash
    Posts: 112 from 2019/11/1
    Your have to use only gcc and g++ command binary in flow studio
  • »08.02.20 - 18:36
  • MDW
    MDW
    Will gcc-9 be used if I set in project settings gcc and g++?
    I am not sure because in GG:bin/ I see:
    ppc-morphos-gcc <link to ppc-morphos-gcc-2.95.3>
    ppc-morphos-gcc-2.95.3 <file>
    ppc-morphos-gcc-4 <link to ppc-morphos-gcc-4.4.5>
    ppc-morphos-gcc-4.4.5 <file>
    ppc-morphos-gcc-5 <file>
    ppc-morphos-gcc-7 <file>
    ppc-morphos-gcc-8 <file>
    ppc-morphos-gcc-9 <file>
    ppc-morphos-g++ also is link to ppc-morphos-g++-2.95.3
    So gcc and g++ probably use gcc-2.95.3, not gcc-9.
  • »09.02.20 - 09:45
    tolkien
    Posts: 585 from 2013/5/29
    type in a shell "gcc -v" and see to what version gcc is refered
  • »09.02.20 - 11:47
    Flash
    Gcc —version, under mos 3.12 or better should be v9
  • »09.02.20 - 12:37
    Posts: 3336 from 2003/3/5
    Err, you've just hit a bug in Flow. It'll probably work OK if you re-create the project.
    On a side note, I do NOT recommend using 'gcc' in your makefiles, etc. Always best to use the full name. Saves problems if you want to cross-compile your project or target different archs explicitly.
  • »09.02.20 - 15:35
  • MDW
    MDW
    Hehe. Ok, I will recreate project. However I probably have to keep gcc8 because my code is not ready for gcc9. :) And I have strange message "unrecognized option '-MP'". I am not sure if gcc9 allows to force C++ standard (e.g. -std=c++11). This version of gcc works strange for me. :)
    Ok, I will specify version of gcc/g++ in each project. :)
    [ Edited by MDW 09.02.2020 - 19:33 ]
  • »09.02.20 - 17:15
  • MDW
    MDW
    If I create new empty project, and select "gcc-9" and "g++-9" (in "Project Settings"), full name of gcc version also is not visible next to cycle button. So re-creating project doesn't help.
  • »21.02.20 - 20:28
  • IKE
    IKE
    Posts: 150 from 2009/11/7
    I am encountering the same mkdir issue as mentioned above whether it is a new or existing project and across various compiler selections.
    IKE
    IKE
  • »26.02.20 - 18:18
    Nadir
    Posts: 178 from 2003/3/17
    Yes, that's a confirmed bug in the latest FlowStudio release. I'm sorry but you will have to either pick the gcc option or set the compiler name manually to ppc-morphos-gcc-9. This has been fixed in the meanwhile but you will have to wait for the next MorphOS release for the update.
  • »27.02.20 - 08:55
    connor
    Posts: 650 from 2007/7/29
    You could update the SDK and include the fixed FlowStudio. Then people don't have to wait for the next MOS release.
  • »27.02.20 - 09:21
    An SDK update is mostly ready. We might include a Flow Studio update in it for sure.
    The only problem is that the machine I use to build the SDK is currently unusable - crashes when compiling :| I've replaced the PSU, the box passes ASD tests just fine and still... Guess either the mobo or CPU are faulty. I'll look into the SDK as soon as I can secure a new G5.
  • »27.02.20 - 11:02
    Nadir
    Well, let's see. To be honest, I don't really see the need for an emergency bugfix when one can just set the compiler manually in the string gadget for the time being.
  • »27.02.20 - 11:49
  • IKE
    IKE
    Thanks for the clarification
    IKE
    IKE
  • »27.02.20 - 13:25
  • MDW
    MDW
    No problem. If I know that update fixes the issue, I can wait. Thank you for support! Flow Studio rules! 😃👍
  • »27.02.20 - 13:53
    Posts: 81 from 2020/5/1
    I have the latest SDK and still get the MKDIR error. What's the workaround until it's fixed?
  • »12.05.20 - 18:31
    tolkien
    You can use Custom compiler and type gcc. It will use gcc 9.
  • »12.05.20 - 18:38
    Still the same (from the first post, but exactly the same problem):
    ### Build Start ###
    ### Build End ###
    What's the operand that mkdir is missing?
  • »12.05.20 - 18:51
    tolkien
    and what about with: ppc-morphos-gcc-9 ?
    I using it without problema.
  • »13.05.20 - 17:17
    Still the same. (Flags, Include paths and Definitions are empty.)
    Compiling from console is of course working fine.
  • »13.05.20 - 20:03
    Posts: 847 from 2007/10/23
    Just for the record
    > ppc-morphos-gcc --version
    2.95.3
    > gcc --version
    gcc (GCC/MorphOS) 9.3.0
    Copyright (C) 2019 Free Software Foundation, Inc.
    This is free software; see the source for copying conditions. There is NO
    warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
    FlowStudio was using the first one
  • »06.11.20 - 14:05
    I don't know if you have already replaced your G5 yet, but I have a spare Dual 2.7GHz G5 I could donate, if needed. Are you still in Canada, or back across the "Pond"? Shipping to Europe would be too expensive, but to Canada, it wouldn't be prohibitive.
    [ Edited by amigadave 06.11.2020 - 12:30 ]
  • »06.11.20 - 19:29
