Disable second G5 CPU
    Cool_amigaN
    Posts: 776 from 2011/11/30
    Will it be possible to physically remove the one cpu and boot straight into MorphOS by disable the one cpu? Or both should be installed and one gets deactivated after you boot into MorphOS?
  • »25.03.18 - 19:11
    beworld
    Posts: 669 from 2010/2/10
    +1
    I test to disable second CPU.. but not effect....
    Any idea ?
    thanks
    IMac G5 2.1, PowerBook G4 1.5, MacMini 1.5
    My MOS ports
  • »28.03.18 - 07:41
    zukow
    Posts: 650 from 2005/2/9
    Have You checked power consumption or temperature inside Your G5?
  • »28.03.18 - 07:56
    beworld
    i show 2 CPU in task manager.
    Temperature : 84 - 86 C ....
    My MOS ports
  • »28.03.18 - 09:14
    Doesn't 3.10 disable the second cpu?
    That should reduce temperatures.
  • »30.03.18 - 13:38
    Posts: 1370 from 2010/1/6
    On my G5 (2.3GHz) it probably does: CPU1: 75°C, CPU2: 52°C ! Under MOS 3.9 both CPUs had about 72°-76°C
  • »30.03.18 - 16:34
    Posts: 899 from 2003/3/4
    You can get a plug in wattage tester for less than 10 euro these days. Always handy for diagnosing issues with equipment.
    I suspect though that disabling one G5 won't result in drastic difference in power consumption, if it's still idling at ~50C. But still, it's something.
  • »30.03.18 - 19:08
    bash64 wrote:
    If I disable and then pull one of the cpus will MOS get confused?
    Can I run with just one?
    Almost 5 years later, I finally made time to test my faulty dual 2.5GHz G5 PowerMac, with one of the two G5 CPU's removed from the system completely. It does not boot, or even appear to attempt the boot process.
    During this removal for testing, I did find what is wrong with my dual 2.5GHz G5 PowerMac, which prevents one of the two confirmed working G5 CPU's from showing up as working.(I have swapped them, and the same G5 unit numbers report working and non-working, when the G5 CPU modules are swapped) The motherboard socket for the upper G5 CPU has 2 or 3 pins that appear to have been bent over and perhaps burned away due to a short circuit, or broken off, due to multiple installation and removal attempts.
    Once I obtain some new "O"rings and replacement coolant liquid, I plan to re-assemble this dual 2.5GHz G5 PowerMac, install a demo copy of latest version of MorphOS available at that time, and then give it away as a raffle prize at this year's AmiWest Show. Since only one of the G5 CPU's is working and it is not worth the effort of trying to repair/replace the faulty G5 CPU socket, this G5 is only good for running MorphOS alone, and much less useful as a dual boot system, with any other OS which is SMP capable.
  • »11.04.18 - 19:57
    Posts: 12504 from 2003/5/22
    At least that's what the MorphOS 3.10 release notes state. In another thread, a user suggests that the 2nd G5 CPU is not really disabled but still idling somehow, thus still consuming energy, albeit less than with MorphOS 3.9 and before.
    Can anybody from the MorphOS team (or anyone else privy to that info) please explain what the "disabled" term really means technically, e.g. with regard to clock rate?
  • »10.11.22 - 20:06
    To explain what I mean (see other thread):
    Screenshot taken from my 2.3GHz G5, MorphOS3.17. As you can see CPU2 is not really deactivated and doing something.
    Both CPUS are about 30sec after powering on PowerMac (MOS has booted complete) on ~30°C. Then CPU1 raises up more than CPU2.
    Difference is always about 15°C - 25°C
    And the situation after 20 min:
    and after 40min:
    But here you have to consider, without limitation temp to 65°C, CPU 1 goes up to 80-90°C and CPU 1 would have in that case about 70°C (diffference is on all temp-levels always nearly the same). Can see that also if you're looking at Fan-Speed - CPU1 works and CPU2 does something whatever else...
    2nd detail: As you can see backsidetemp (North Bridge) is on 65°C (limitid to 65°C by me - would go higher), while Northbridge temp on my other G5 with only 1 CPU/2,3GHz mounted, stops at maximum ~ 47°C (This machine is running since 3h)
    [ Editiert durch Amigaharry2 11.11.2022 - 09:38 ]
  • »11.11.22 - 07:07
    > To explain what I mean (see other thread): [...]
    Yes, thanks. I think I understand what you mean. Let's hope the MorphOS team will clarify what changed regarding the handling of the 2nd G5 CPU starting with MorphOS 3.10 and how that constitutes a "disabling", compared to leaving it enabled/idling on the one hand and compared to having it physically removed on the other hand.
    (On a related note, it would also be interesting to know how the "disabling" of the unused PPC970 CPU compares to the powering down of the X5000's unused e5500 core(s)).
  • »11.11.22 - 07:42
    LazarX
    Posts: 7 from 2020/4/30
    Intuition wrote:
    It's possible to disable the unused second CPU in Open Firmware with the following commands:
    setenv boot-args cpus=1
    reset-all
    That should save your electricity bill a few quid and lower the temperature a bit too. :)
    It won't save you one red cent.
  • »17.11.22 - 23:13
    Indeed, see comment #18.
  • »18.11.22 - 06:27
