    Jambalah
    Posts: 820 from 2008/3/30
    ..strange... I clicked on the link and it works.
    It takes 3 or 4 minutes to load but it works..
    Pegasos II 1 ghz
    Powermac G5 dual 2.0 ghz
    Powerbook G4 1.67 ghz 17
  • »28.10.08 - 15:34
    Golem
    Posts: 766 from 2003/2/28
    A current MorphOS mplayer will play the file just fine. You failed to say what you're actually using.
  • »28.10.08 - 15:39
    Neko
    Posts: 301 from 2003/2/24
    jcmarcos:
    Indeed... Notice the complete absence of Genesi's SmartFirmware?
    That's nothing to shout about, you can code any OS to run on any firmware you like, and we don't care.
    As it stands Apple's PowerPC systems all run OpenFirmware, so there's very little difference all told. MorphOS really doesn't use OF after a certain point in boot (basically a few fractions of a second after it says Quark/OpenFirmware, it's done with OpenFirmware and has called quiesce)
    Matt Sealey, Genesi USA, Inc.
    Developer Relations
    Product Development Analyst
  • »29.10.08 - 16:34
    Neko
    jcmarcos babbled:
    There's been a considerable amount of discussion about PCI risers in PowerDeveloper.org, but not a clear "hey, I have this working" post from anybody.
    Matt Sealey said that Adex Electronics has compatible ones, but there's a lot more to read before doing anything. It's not something that's been already tried and tested.
    The Adex risers are tried and tested. You just have to order the CORRECT configuration.
    The MPC5200B can support a load of 2 PCI cards on it's bus, the riser overcomplicates things, and needs to be designed a certain way to make it work. No such riser exists in the world.
    You can get away with one card in a single-card riser as Adex sell, without problems. The smallest one they sell is exactly the same height (actually about half a millimeter too short) as the AGP riser. It will allow you to put any low-profile 3.3V PCI card into the slot and expose it on the Open Client back panel, for example.
    Developer Relations
  • »29.10.08 - 16:38
    It works on my Windows PC, but would not play on my MacBook via QuickTime. Strange.
  • »30.10.08 - 01:55
    Jambalah
    Sorry amigadave... I explained myself in the wrong way.. Sometimes I speak as I'm still typing on my Peggy (I saw that video with it the first time using MPlayer) and yes, it works with Windows. I didn't realize you were trying to play it with Mac..  :-)
    Pegasos II 1 ghz
  • »30.10.08 - 04:22
    Posts: 2069 from 2003/6/4
    Quicktime sucks anyway. Get MPlayer for OS X.
  • »30.10.08 - 11:12
    CountRaven
    Posts: 566 from 2007/12/10
    > Any update on this ?
    http://piru.morphos.net/~p/pics/morphos-macmini.jpg (from August 22nd)
    http://piru.morphos.net/~p/pics/morphos-macmini2.jpg (from August 27th)
    have I missed something?
  • »08.11.08 - 11:49
    Golem
    Yes.
  • »08.11.08 - 12:01
    CountRaven
    Can anybody spread some light? Any link or whatever? I hardly got time to follow all the updates and news...
  • »08.11.08 - 12:31
    Golem
    You could try asking specific questions, maybe read this thread.
  • »08.11.08 - 13:28
    jcmarcos
    Posts: 1178 from 2003/3/13
    You might find this interesting:
    "Last weekend in Bad Bramstedt a h264 1080p video was fluently replayed on a 1.42 GHz Mac Mini running MPlayer/MorphOS"
    Yippieeee...
  • »10.11.08 - 12:01
    CountRaven
    Has anyone saved those images and can be kind enough to send em to me? Piru's site is down ATM I viewed the images but have not saved em. Thanks.
  • »10.11.08 - 13:41
    Posts: 2727 from 2003/2/24
    If it was down, it's up again now. It works here!
  • »10.11.08 - 15:35
    TheMagicM
    Posts: 1220 from 2003/6/17
    when is the release date?
  • »11.11.08 - 04:03
    Sir_Lucas
    Posts: 112 from 2006/4/23
    Bad Bramstedet was told, MOS2.2 the way this year to come. But still no Mac support.
    MOS 2.3 will be when everything is running according to plan, perhaps even in the first quarter of 2009 coming. This has also a Mac support.
    First, for all MiniMacs with PPC CPU and perhaps even later for iBook and PowerBook with PPC and Radeon graphics card. (about it but was not made clear statement because the developer does not currently own has iBook or PowerBook.) How Insane already has written to the Mac Mini lacks only sound and Lan driver. And the memory access was a MacMini with a 1.42 Ghz twice as fast as when Pegasos2.
    A BlueRay video was smooth on the Mplayer played.
    I myself had been a Mac Mini with 1.42 GHz 32MB graphics card. I still had the model with 1.5 GHz and 64MB graphics increased.
    Source. I used Google translator as I don't speak German.
    Click
    Here are some pictures.
    Link
    Link2
  • »11.11.08 - 09:00
    dIGIMAN
    Posts: 273 from 2005/11/7
    Is there a way i could still use my UW SCSI Drives on Mac Mini together with MorphOS?
    Hope so, otherwise its no option for me :/
  • »11.11.08 - 09:41
    SoundSquare
    Posts: 1214 from 2004/12/1
    check the mac mini if you never saw one, i really don't see how you could plug any scsi drive in there...
  • »11.11.08 - 09:56
    TheMagicM
    lol..yea them MorphOS developers... freakin smart dudes. to be able to switch from one platform to another within a small timeframe..it says alot about them. Great work!!
  • »11.11.08 - 10:19
    dIGIMAN
    Well there are USBSCSI Adapters, but i guess that wont get me nowhere.
    To bad
  • »12.11.08 - 14:02
    Painkiller
    Posts: 128 from 2007/11/19
    Well actually doesn't those USB-SCSI adapters actually act like a standard mass storage device, so it should work.
  • »12.11.08 - 18:27
    KimmoK
    Posts: 102 from 2003/5/19
    When is MOS planned to be released for MMini? :-?
    (I'm becoming a owner of MacMini, but I'm not going to use OSX)
    :-x  :-P  8-)
  • »13.11.08 - 05:34
    Simon
    Posts: 809 from 2008/7/6
    @painkiller
    depends on what you want to connect ... harddrives ok ... CDwriter, scanners, ... not ok.
  • »13.11.08 - 05:49
    Simon
    @Kimmok
    no OSX ? well I guess you an use it as a lunchbox then ?
  • »13.11.08 - 05:51
    KimmoK
    @Oepabakkes
    If it does not run MOS soon, it will end up as digital TV recorder. Linux is the king at that.
    :-x  :-P  8-)
  • »13.11.08 - 06:36
