A-EON AmigaOne X5000/20 works great with MorphOS!
    Posts: 2720 from 2003/2/24
    @ jacadcaps
    Maybe a "first run" welcome page (after new install of a new version), loaded from the wayfarer.icu site that can be updated quick and easy (with local basic fallback), with tips and tricks for configuration etc? :-)
  • »16.10.20 - 20:37
    discreetfx
    Posts: 388 from 2003/7/26
    Looks really nice! I wish I had a GPU on my X5000 that supported MorphOS and AmigaOS 4.1
    DiscreetFX
    Making your
    Digital Films
    More Effective!
  • »19.10.20 - 16:12
    That must be terrible...
  • »22.10.20 - 18:23
    Flash
    Posts: 105 from 2019/11/1
    xeno74 wrote:
    No, it’s fast and stable. I am surprised.
    Good job!
    Did you use KVM-PR for QEMU? Is there any way to enable tthis?
  • »23.10.20 - 06:32
    Posts: 12080 from 2003/5/22
    > it’s fast [...]. I am surprised.
    This would come as a surprise for me too. How fast is 'fast' (in terms of CPU benchmarks like dnetc, for instance)? I assume that despite both cores being Book III-E, the PPC440H6 core is running fully emulated on the e5500 core, rather than using KVM-PR to emulate just the supervisor instructions.
  • »23.10.20 - 08:43
    Flash
    Indeed QEMU is quite fast in CPU/Memory related tasks.
    With TCG dinamic compiler all powerpc code is translated in host native asm code, with instruction cache support to avoid to repeat the same work again and again..
    Tested it with various software on OS4 and MOS, some written/ported by myself :-)
    Big slowdown appears on GFX task, at least on OS4.1 emulation.
    This specific issue is, at least partially, due the SM501 emulated board and it's internal 32bit mode VS only 16bit screenmodes support on amiga side.
    Balaton Zoltan is developing an ATI vga alternative for both MOS/OS4 that shouild be faster and more compatible, even for 3d stuff.
    He is also planning a Pegasos2 virtual board for QEMU and possibility to run MOS/OS4 in KVM mode on powerpc machines like Powermacs G4/G5.
  • »23.10.20 - 10:17
    discreetfx
    @Flash
    Do you have a link to setup MorphOS in this VM like environment?
    DiscreetFX
    Making your
    Digital Films
    More Effective!
  • »23.10.20 - 13:37
    Flash
    Look at Xeno74 post #40
    Open the png image link an use the same QEMU launch string used in its terminal window.
    I have never launched MOS on QEMU, I used only Sam460ex OS4.1fe, so I can't give you a direct support.
    Maybe Xeno74 can give some tips about
  • »23.10.20 - 15:50
    Thanks.
    > [...]. He is also planning a Pegasos2 virtual board for QEMU
    Yes, we talked about those projects some months ago :-)
  • »24.10.20 - 00:49
    Fogg_80
    Posts: 45 from 2007/11/12
    Hedeon wrote:
    How does it run on the X5000/40?
    @xeno
    Have you an answer!!??
    Stile Ubuntu
    Sorry for my bad english.
  • »07.12.20 - 13:28
    xeno74
    Posts: 40 from 2020/6/8
    Fogg_80 schrieb:
    @xeno
    I think it works on the X5000/40 but I haven't tried it yet. I need another graphics card for MorphOS on the X5000/40.
  • »07.12.20 - 13:42
    Fogg_80
    Unfortunately on my X5040 Uboot don’t support MorphOS. Is Uboot the problem!!!???
    Stile Ubuntu
  • »07.12.20 - 14:15
    What’s the version of your Uboot?
  • »07.12.20 - 16:02
    xeno74
    Hi All,
    Happy New Year 2021! Many thanks for the great update! I was able to update to MorphOS 3.15 on my AmigaOne X5000/20 today. I will test the new version in the next days.
    Screenshot: f0ce19ed8e6d8239cf7b2953b4403dba.png
    A-EON AmigaOne X5000 Update Instructions
    You will need a 500MB or larger USB disk
    Prepare the USB Disk
    Copy the image to a USB disk
    Linux Instructions
    With your system powered on, insert a USB disk that is at least 500MB into a USB port
    Determine the /dev path to your USB disk using one of the below methods:
    - In a terminal as su or sudo, enter "fdisk -l"
    - In a terminal as su or sudo, enter "parted -l"
    - Check the GParted menu in the upper-right corner
    These instructions assume the /dev path to your USB disk is /dev/sdz; however, your actual /dev path is likely to be different - use the actual /dev path to your USB disk
    In a terminal as su or sudo, enter the below command:
    dd if=/path/to/morphos-3.15-hybrid.hdimg of=/dev/sdz
    where "/dev/sdz" is the /dev path to your USB disk
    NOTE: Do not attempt to copy the image to a specific partition - you need to enter the /dev path to the disk, not to a partition (use "/dev/sdz", not "/dev/sdz2")
    Mac Instructions
    Open the Terminal app in Applications > Utilities
    Determine the /dev path to your USB disk by entering the below command:
    diskutil list
    These instructions assume the /dev path to your USB disk is /dev/disk9; however, your actual /dev path is likely to be different - use the actual /dev path to your USB disk
    Enter the below command:
    dd if=/path/to/morphos-3.15-hybrid.hdimg of=/dev/disk9
    where "/dev/disk9" is the /dev path to your USB disk
    Windows Instructions
    With your system powered on, insert a USB disk that is at least 500MB into a USB port.
    Download "USB Image Tool" from alexpage.de
    Open USB Image Tool
    On the left panel, select your USB disk
    Click the "Restore" button and select the MorphOS disk image
    Boot to MorphOS
    Begin with your A-EON AmigaOne X5000 system powered down and insert the USB disk into a USB port - remove any other USB disks that are plugged in.
    Power on your system and press ESC when the boot animation starts to load the U-Boot menu.
    Choose "Command Line" from the U-Boot menu
    Type the following commands:
    usb reset
    bootmorphos
    After selecting the language and keymap please select "Installation ..."
    Choose "Update Installation"
    Choose the MorphOS volume and the button "Update".
    After that please shutdown MorphOS (Ambient - Shutdown... - Shutdown) and remove the MorphOS USB stick.
    Please start the AmigaOne X5000 and the new MorphOS 3.15 will boot automatically.
    Cheers,
    Christian
    [ Editiert durch xeno74 02.01.2021 - 11:57 ]
  • »02.01.21 - 11:39
    discreetfx
    Has dual booting been resolved for the AmigaOne X5000/20 yet? I want to use MorphOS and AmigaOS 4.1 on my X5000 with a modern GPU that supports most features.
    DiscreetFX
    Making your
    Digital Films
    More Effective!
  • »17.02.21 - 23:47
  • esc
    esc
    Posts: 152 from 2013/5/28
    The triumvirate of OSes that can run on the X5000 (OS4.1FE, MorphOS, linux) still lack a fully featured common GPU implementation.
  • »18.02.21 - 09:32
    Posts: 358 from 2019/5/9
    And will lack in the future.
    Is theoretically possible, that MorphOS and AmigaOs will have support for the same more modern cards, but I think linux will never have it.
    There is a bug in amdgpu PPC big-endian version, and new improvements focuses on little-endian.
    But who knows, maybe I'm wrong and someone will be dealing with decades old things from which he has no profit, except joy ;-)
    AmigaOS4: Micro A1-C, AmigaOne XE, Pegasos II, Sam440ep, Sam440ep-flex, AmigaOneX1000
    MorphOS: Efika 5200b, Pegasos I, Pegasos II, Powerbook G4, Mac Mini, iMac G5, Powermac G5 Quad
  • »18.02.21 - 11:52
    Posts: 779 from 2007/10/23
    @sailor
    Are you talking about this?
  • »18.02.21 - 20:03
    discreetfx
    Personally I’m not interested in running Linux on the X5000. I have plenty of other machines I can run Linux on. It would be really nice to dual boot MorphOS and AmigaOS 4.1 on the X5000 with a newish GPU. Or even better the architecture shift solution finally arrives for MorphOS. I understand OS development is hard work, so I guess good things come to those who wait.
    DiscreetFX
    Making your
    Digital Films
    More Effective!
  • »19.02.21 - 05:04
    polluks wrote:
    @sailor
    I dont know exactly - I know that Nvidia Nouveau have problem with kernel page size, custom kernel with 4kb page is needed on big-endian. I was playing with this when I had FX4500 inside my Quad.
    Regarding the amdgpu I know only that it doesn't works on big-endian ;-), thus we must use radeon, i.e. we are limited to northern island and lower cards.
  • »19.02.21 - 08:07
