How to run MorphOS on unsupported iMAC G5
    Posts: 12078 from 2003/5/22
    > Seriously ? This simple option is enough
    Yes, since MorphOS 3.12.
  • »27.06.21 - 13:11
    cip060
    Posts: 137 from 2010/7/30
    I have a 20 inch isight imac g5
    I don't have much space in my workstation the only solution would be to put it behind the LCD TV
    If I connect the mini vga socket to my pc monitor that I use every day, would morphos work?
    Could it work if I unplug the imac lcd monitor by unplugging the connectors?
    Using the mini vga of course
    In theory it should behave like a laptop
    Has anyone tried this?
  • »11.08.21 - 12:44
    Posts: 2973 from 2003/3/5
    If you really want to do something like this, it would likely be better to disconnect the internal panel and route the DVI signals out of the box - the internal plug is actually a proper DVI, which will go up to Full HD resolution easily.
    (edit: to be precise, it's not a DVI plug, but the signals are the same)
    [ Edited by jacadcaps 11.08.2021 - 15:28 ]
  • »11.08.21 - 13:27
    Posts: 1246 from 2004/2/8
    So you say some cable-soldering fun would be needed then? Or is there an adapter somewhere?
  • »11.08.21 - 15:12
    cip060
    No but I don't want to use the imac monitor for anything else !!
    i want to detach the lcd monitor and use it with a monitor of my pc through mini vga socket with morphos
    you think it would work
  • »11.08.21 - 17:52
    I doubt you'll get any video on the VGA port.
  • »11.08.21 - 20:51
    >> why does the G5-20" work and the G5-17" 1,9Ghz (x600pro) not?
    > Yes, support (unofficial) for the 17" A1144 would be useful.
    Seems it's there now:
    "Devs/Monitors/Radeon
    [...] Added iMac G5 17" iSight compatibility
    https://www.morphos-team.net/releasenotes/3.16
  • »09.03.22 - 14:32
    Posts: 2239 from 2003/2/24
    Yes and no.
    The iMac is one of the few supported options for dual-monitor support so if he sets up Ambient to show up on the external screen before removing the buildin panel he should be good. Until that setting gets lost for one reason or another....
  • »09.03.22 - 15:08
    Posts: 358 from 2019/5/9
    I continue with interesting discussion started ( a liitle offtopic ) here: iMac G5 overclocking
    Little terminology corner:
    CPU bus: = Processor Interconnect ( IBM terminology ) = Elastic Interface ( Apple schematics terminology ) = Processor interface bus ( Apple bussiness terminology )
    Northbridge: = U4 ( Apple bussiness ) = CP945 ( IBM ) = Kodiak ( Apple schematics )
    Fortunatelly, I receive iMac iSight G5 ( A1145 ) and iMac G5 A1058 (which is very probably version overclocked in above links ) schematics.
    I can confirm, that resistors responsible for CPU bus clock configuration 3:1 -> 2:1 are:
    iMac G5 1.8 GHz A1058: R3012 -> R3028, exactly like mentioned in above links
    iMac G5 iSight 2.1 GHz A1145: R4712 -> R4728
    Accordind to Northbridge and CPU manuals, the CPU bus clock domain is independent from other clock domains, so CPU speed not change with change of CPU bus speed ( in opposite of G3+G4 overclocking, where CPU frequency derives from bus frequency).
    So, all this is theory. In praxis there still can remain risk of damage, because of:
    - inappropriate version of real iMac iSight and schematics (not too big risk)
    - Northbridge in iMac can have lower "Speed Classification", i.e. maybe in real is not 1.05 GHz capable
    - insufficient cooling after bus overclocking
    - damage during mounting / dismounting / soldering
    - other things I didn't notice
    [ Edited by sailor 20.05.2022 - 08:20 ]
    AmigaOS4: Micro A1-C, AmigaOne XE, Pegasos II, Sam440ep, Sam440ep-flex, AmigaOneX1000
    MorphOS: Efika 5200b, Pegasos I, Pegasos II, Powerbook G4, Mac Mini, iMac G5, Powermac G5 Quad
  • »19.05.22 - 10:28
    In fact, Elastic Interface is a term coined by IBM and adopted by Apple.
    > U4 [...] = CP925 [...] = Kodiak
    Seems the confusion still prevails:
    CPC925 = U3/U3H
    CPC945 = U4 = Kodiak
  • »19.05.22 - 12:39
    @Andreas
    corrected. Too much too similar numbers.
  • »20.05.22 - 07:21
    And if I study our iMac G5 iSight Schematics, there is another interesting findings:
    iMac use SATA connected HDD and ATA connected DVD.
    But in real, used Southbridge have two SATA ports, and only one is connected.
    If anybody wants (and he finds appropriate pins on motherboard) I have the scheme how to connect it. It needs four additional condensers, but it is not too complex.
    Then you can connect or modern SATA optical drive, or second SATA HDD (with both disks 2.5" size to fit to one 3.5" bay).
    Of course, it is only HW point of view. I am not sure if OpenFirmware or OS recognized device which was not taken into account.
    Southbridge is Broadcom, type (yet) unknown, but can be ( at least partially ) identified by PCItool, device ID. Apple codename is SHASTA. But for SATA port addition no identification is needed.
  • »20.05.22 - 07:40
    NewSense
    Posts: 1475 from 2012/11/10
    I've been using my iMac A1145 for a while now, and for some reason I never noticed, until now, that there doesn't seem to be a brightness option, as far as I can tell, for it in preferences to reduce or increase that feature of the screen itself, or does someone know how to adjust the screen brightness on these iMacs? :-?
    There is of course a keyboard control for the PowerBooks, and other notebook type hardware. For the MacMini you need a separate screen that usually has some independant way to adjust the screens brightness but with the iMac there doesn't seem to be this feature supported, as yet, is this an oversight, or a problem in working out just how Apple got it to function with Mac OSX, and make it work within MorphOS? :-?
  • »15.08.22 - 02:29
    The API for that exists and I do have a primitive 20% ready screenbar module that uses it.
    Maybe I‘ll do the next 75% once I get the new PastePass out of the door.
    If I look at what my boss thinks about the use of my time that may end up being in the year 2525……
  • »15.08.22 - 05:24
    I’ll be bringing some of the PowerBook services to the iMac support for 3.18…
  • »15.08.22 - 12:14
    MoerBoer
    Posts: 210 from 2019/10/15
    Very cool!
    Any idea how hard it is to get a bootscreen going for there?
  • »15.08.22 - 18:32
    Posts: 4 from 2020/10/13
    Just hit a brick wall on trying to update my G5 iMac iSight 20" to 3.17 (currently running 3.16). I'm trying to boot from USB (can't from the optical as it is non-functional), but after the 'quiescence' message I'm getting the following error:
    Invalid memory access %SRR0: 00000000.00c02230 %SRR1:100000000.00003030
    I've tried re-downloading the iso in case it was a download error, but hit he same problem. Any help would be much appreciated!
    Thanks,
    Nigel.
  • »15.08.22 - 18:53
    bigfoot
    Posts: 508 from 2003/4/11
    You're probably booting the wrong boot image. You need use the boot image from the mac_ppc64 directory, not the mac_ppc32 directory.
  • »15.08.22 - 19:10
    Ah, user error, might have known! Many thanks, I'll give that a try,
    Cheers
    Nigel.
  • »15.08.22 - 19:46
    Posts: 779 from 2007/10/23
    Indeed, an architecture check at the beginning would be helpful. Maybe at OFW level somehow?
    [ Editiert durch polluks 16.08.2022 - 17:48 ]
  • »16.08.22 - 16:45
