MorphOS 3.19
    Trekman
    Posts: 50 from 2020/11/10
    First of all : Thaaaanks to the MorphOS Team for this new release .... :-) :-) :-)
    Installation went fine. So far everything works.
    An old Problem appeared again for my Radeon9600Pro.
    The .1 Screenmodes disappeared and the second monitor stayed with a black screen.
    After putting the Radeon driver in /devs/monitors back to the one from MorphOS 3.17 (v52.39) it works again. ;-)
  • »18.01.25 - 14:37
    tolkien
    Posts: 582 from 2013/5/29
    I have had a problem with last MorphOS updates.
    My systen partición was done by MorphOS years ago (2gb?)
    Now It fails to install cause there is no space in It.
    I use the option to clean systen but It is not enough.
    Should be an option to not make backup or put It in another partition.
    I have to sabe some data to other partition, delete from system and then restore.
    Any idea what can be done in future updates?
  • »18.01.25 - 19:16
    Trekman
    The system partition should have at least 8GB.
    Thats what is set at install normally.
    Did you change it to 2 GB at first install ?
    Maybe that explains it. I would recommend doing
    a backup of your data and then doing a fresh install
    with the standard settings.
    That should solve this problem for future updates. ;-)
    Do not forget to save your MorphOS keyfile before reinstalling.
  • »18.01.25 - 19:30
    Dragster
    Posts: 99 from 2005/11/6
    ...and The MorphOS Team does it again! Yes! Thank you!
  • »18.01.25 - 20:14
    tolkien
    It seems I should change It but dont remember. It was 12 years ago or so.
    I will have to backup and reinstall.
    Thanks!
    [ Editado por tolkien 18.01.2025 - 23:32 ]
  • »18.01.25 - 21:31
    Flash
    Posts: 112 from 2019/11/1
    Great to see an active developmemt for an AmigaOs system.
    This is mainly a bugfix release, I hope there will be some substantial feature in 3.20
  • »19.01.25 - 04:08
    Posts: 478 from 2019/5/9
    @morphosdevs
    please, what does mean in practice this 3.19 upgrade ?:
    Quark: When accessing the regular PCI bus, do a type 1 configuration transaction (Sam460LE)
    As I understand type 1 is checking root complex / host controller, type 0 checking endpoint / device. But I do not know difference in practice.
    On real Sam460LE was in previous version issue, that in PCIe x1 slot was not visible cards behind the bridge ( like CMI8738, which is PCI with PCI-PCIe bridge ).
    This issue remains in MOS 3.19, it means PCI configuration change doing something else. Probably it concerns only to PCI host, not two PCIe roots.
    In any case, MorphOS on Sam460LE is very good, fast and stable. Thanks.
  • »19.01.25 - 07:03
    Posts: 846 from 2007/10/23
    FYI type 1
  • »19.01.25 - 10:06
    Thanks!
    Well, I just update by manually copying to MOSSYS:. Not recommended but works.
  • »19.01.25 - 10:17
    Posts: 12550 from 2003/5/22
    Yes, as expected because 19 is an odd number.
    That should be the case because 20 is an even number.
  • »19.01.25 - 11:58
    Posts: 2217 from 2003/2/24
    IIRC the default size with the Installer was 2 GB in the (very) old times, but the default was changed to larger value at some point, because 2 GB became too small. So, if your original installation is very old, you still might have a small system partition.
  • »19.01.25 - 12:06
    Brumiga
    Posts: 277 from 2004/4/3
    @MorphOs Team,
    I saw somewhere in the past the instructions to perform the burn of img or hdimg file to a usb stick. But I absolutly do not remember where. On your site the instructions of installation do not speak about the AmigaOne X5000.
    Can you give here the instructions to perform the burn of img or hdimg file to a usb stick under MorphOS ? Others, do not give a link, I prefer the answer here directly.
    Brumiga
  • »19.01.25 - 12:58
    Brumiga
    @BatteMan,
    Thank you but you are wrong. Have you read carefully the beginning of thr tuorial you linked ? It is designed for apple mac computers only.
    I search for the instructions to burn img or hdimg file to usb stick. It can be peformed under linux with etcher or dd commandline, under windows with etcher too or with winimage. Under macos x I do not know. But what I want is to perform this under MorphOS. It is possible, I saw the instructions but where, that I do not remember. And also it is better if performed under MorphOs than any other system. That prooves the possibity to use MorphOS for this purpose.
    Brumiga
  • »19.01.25 - 14:52
    Mozzerfan
    Posts: 105 from 2016/10/5
    @brumiga
    https://morph.zone/modules/newbb_plus/viewtopic.php?topic_id=13513&forum=11#156083
  • »19.01.25 - 18:02
    Here's some instruction (not mine, haven't tested): https://amiga-news.de/de/news/comments/328439.html
    Contents of that link:
    1.) das Image speichert man sich irgendwo
    2.) einen leeren USB-Stick anschließen, sich den Port merken (leider erkennt im Gegensatz zu OS4
    MorphOS manche nicht bzw. hat Probleme damit)
    3.) Befehl in Shell:
    Copy morphos-3.19-hybrid.hdimg RAWDISK:Devices/usbscsi.device/0/rawdisk DIRECT
    (hier mit USB-Stick am Port 0)
    4.) X5000 neu booten ins Early Startup Control Menü
    5.) dort NICHT auf MorphOS, sodern auf den untersten, letzten Eintrag "Command Line"
    6.) Eingabe von "USB RESET"
    7.) bootmorphos
    Google translated:
    1.) save the image somewhere
    2.) connect an empty USB stick, remember the port (unfortunately, unlike OS4,
    MorphOS does not recognize some devices or has problems with it)
    3.) Command in shell:
    (here with a USB stick on port 0)
    4.) reboot X5000 into the Early Startup Control menu
    5.) there, NOT on MorphOS, but on the lowest, last entry "Command Line"
    6.) enter "USB RESET"
    7.) bootmorphos
    Just make sure you write over correct USB device. Read more about reading/writing image files on MorphOS here: https://library.morph.zone/Tips_and_Tricks#Copying_a_Whole_Disk_As_an_Image_File
  • »19.01.25 - 20:11
    BatteMan
    Posts: 294 from 2003/2/24
    @brumiga : no, i didn't.
  • »20.01.25 - 04:15
    cip060
    Posts: 151 from 2010/7/30
    I have run out of CDs to burn, can I burn the ISO to a DVD?
    Does it work the same?
    I HATE the procedure with a USB stick via the original firmware on the command line
  • »20.01.25 - 07:25
    beworld
    Posts: 683 from 2010/2/10
    I think... test it, better is CDRW or DVDRW :-)
    My MOS ports
  • »20.01.25 - 07:53
    Posts: 31 from 2022/8/17
    It works - I just burned the DVD-R and upgraded Morph OS from 3.18 to 3.19 using it.
  • »20.01.25 - 10:40
    cip060
    Update Error
  • »20.01.25 - 14:33
    Posts: 1357 from 2004/2/8
    Well, there's always the not-recommended way... The Dark One... Quicker, easier, more seductive... Could blow your machine up instaneously...
    1. replace boot.img on your boot partition with the one from ISO (the correct one for your machine!)
    2. reboot old MorphOS with new kernel
    3. mount ISO and run update
    Mind you - this might go wrong if older MorphOS version won't for some reason work well with newer kernel. You have been warned!
  • »20.01.25 - 16:00
    :D
    Yet another option is to have a bootmenu to avoid writing OF commands. I have a secondary boot partition and I can boot my Mac by pressing the Alt key, and then select the secondary partition to get a boot menu shown up instead of booting directly to MorphOS. Then I just press 3 to boot an ISO image placed on the HD or press 4 to boot an image placed on a USB stick. Needs a bit to set up it, but I've done it once 10+ years ago and it's still useful :)
  • »20.01.25 - 17:00
