Hardware compatibility reports to the MorphOS Library
    Papiosaur
    Posts: 2256 from 2003/4/10
    jPV: oops sorry, this is the information:
    Wired Gaming Gamepad
    Brand: BIMONK
    Wireless Joystick
    Brand: BIMONK
    Mini Stick Arcade
    Brand: Mcbazel Dobe
    Wireless mouse Gaming
    Brand:TENMOS
    Model: K6
    [ Edité par Papiosaur 15.06.2021 - 19:23 ]
  • »15.06.21 - 17:21
    Puni
    Posts: 37 from 2020/7/21
    Deltaco Gaming Headphones with Microphone - Wired - 3.5 MM audio plugs
    Brand: Deltaco
    Model: GAM-023
    Works fine on a PowerBook G4 with latest MorphOS. :-)
    [ Edited by Puni 17.06.2021 - 17:50 ]
    Member of Void - An Amiga demo group (website)
  • »17.06.21 - 16:49
    Posts: 2110 from 2003/2/24
    Added Papiosaur's suggestions, but didn't add Puni's headphones, because standard 3.5mm audio plugs should work universally anyway and there isn't difference in compatibility. The list is mostly devices that are connected with USB (it's "USB Audio Devices" category what we've used for headphones etc).
  • »20.06.21 - 08:28
    Puni
    Logitech M100 Optical Corded Mouse - USB (https://www.logitech.com/en-us/products/mice/m100-usb-mouse.910-001601.html)
    IBM SK-8815 Corded USB Keyboard
    Samsung S24D330 24-Inch LED Monitor (https://www.amazon.co.uk/Samsung-S24D330-24-Inch-LED-Monitor/dp/B01HRYELC4?th=1)
    All works with the newest version of MorphOS. :-)
    [ Edited by Puni 21.10.2021 - 12:40 ]
  • »21.10.21 - 11:24
    Cool_amigaN
    Posts: 765 from 2011/11/30
    It worth noting that TL-WR802N
    works great with MorphOS (plus on a 1200 with 3Com pcmcia where I installed a second one) and can transform any ethernet into WiFi. Really great in case your system lacks WiFi whereas also reduces the CPU overhead when communicating to the actual router doing SSL. Set static ip on the nano router/ap and DCHP on MorphOS/Amiga, then you use the static IP to directly connect on the system (i.e. via Samba/NetFS etc). Keep in mind that on v4 you need to connect via WiFi for initial setup (not ethernet like v1). After setting the nano to client mode you can connect and customize via Wayfarer (tested with v4.9) but you must explicitly activate "Ad-Blocker". It has the size of a matchbox and can be easily hidden (even installed inside a PowerMac case). V4 comes with external power supply too or you can power it through a USB port (v1 provides just a cord).
  • »03.03.23 - 14:04
    Posts: 12200 from 2003/5/22
    > TL-WR802N
    I was using the predecessor TL-WR702N with a Mac mini G4 until mid-2014 when MorphOS 3.6 brought support for the Broadcom BCM43 Wi-Fi chipset (AirPort Extreme). Worked like a charm. This device was a popular solution back then for MorphOS users, going by the number of recommendations here on MorphZone during that time. It didn't stay unused for very long, namely only until late 2016 when I switched to a PowerMac G5 without Wi-Fi.
  • »03.03.23 - 18:12
    Cool_amigaN
    Pls add Wacom One Tablet (CTL-472) (tested with latest MorphOS 3.18) :)
  • »07.07.23 - 16:23
    Posts: 1 from 2023/7/10
    Hey, I was the one who posted about this on the FB group. The graphics tablet only half works upon further testing. It doesn't support the pressure sensor nor absolute X/Y, only relative, it's not fully functional, even with Yomgui's WacomFix.elf doesn't correct these issues. Perhaps the MOS team can look into it but I wouldn't say it works 100% out of the box, it simply emulates a trackpad at the time being.
  • »10.07.23 - 14:18
    Cool_amigaN
    The Marvo Scorpion GT-106 Joypad works perfectly (including SDL2 setup).
    Pls update the hardware compatibility list.
    Keep in mind though that when booting the computer, joypad always defaults in Android mode, hence when on Ambient you need to long press the home button for 5 secs so it can revert to PC/PS3 mode.
    Back in Feb. 2020 I 've bought this pad for about 5 euros in Dubai Mall. How on earth this is priced between 25-30 usd currently is beyond me.
    Anyway, it's good quality product, no dead zones, no drifting, nice grip, long cable. Recommended (if you can live with that home button press in each boot which seems to be a trend to all "new" pc/ps3/android hybrid pads).
  • »12.02.24 - 16:44
    NewSense
    Posts: 1513 from 2012/11/10
    Cool_amigaN wrote: The Marvo Scorpion GT-106 Joypad works perfectly (including SDL2 setup).
    MorphOS Library Hardware Compatibility - 2.1 Game Controllers List has been updated with almost those details, as the link and the product on the webpage indicates the device is actually the GT-016 model . 8-)
  • »14.02.24 - 06:39
    Cool_amigaN
    I have been using for almost a year but forgot to mention in this thread, a MT-32 Pi variant, namely the BulkyMIDI-32 with success under every supported midi software I have tested (from playmidi cli command to scummvm and audio software under MorphOS such as Horny etc). Tested under MorphOS version 3.17 and 3.18 with a Roland UM-ONE usb-midi cable (had issues with cheap cables, whereas Tcheko didn't in his setup using the very same cable). I am also using a privately build native version of RaspMIDI which I hope Tolkien finally releases into the public :)
  • »15.11.24 - 08:12
    tolkien
    Posts: 523 from 2013/5/29
    Great that you use my dirty port of Horny and RaspMidi.
    Ill try to release the MorphOS version of RaspMidi sooner than later.
  • »15.11.24 - 11:13
