Replace harddrive Mac mini
    kriz
    Posts: 310 from 2005/10/18
    I get strange errors on the Mac mini (lock up when unpacking and similar), i want to try to change the harddisk.. What are some good solutions in 2023 for this ? SSD possible ? Thanks!
  • »20.07.23 - 19:29
    kriz
    Maybe this Aliexpress msata adapter (44PIN MSATA To 2.5 Inch IDE HDD SSD MSATA To PATA Adapter Converter Card With Case) and a mSata disk.
    Like this one: msata disk) Kingston Technology KC600 mSATA 256 GB Serial ATA III 3D TLC
  • »20.07.23 - 20:48
    kriz
    SFS Doctor found some problems and seems better, but still would be good to get a new drive going :)
  • »20.07.23 - 21:25
    Posts: 471 from 2019/5/9
    @kriz
    look here. Chapter 5 - there are three functional possibilities of Mini HDD replacement. In Czech language.
    Of course, there are probably more ways howto do it.
  • »21.07.23 - 03:17
    kriz
    @sailor Thx! Yes it looks like same solution i found here with the mSata :)
  • »21.07.23 - 05:58
    Templario
    Posts: 555 from 2012/4/28
    Also you can ask to Papiosaur if still he has SSD hard drives or adapters from his store.
    Here https://www.meta-morphos.org/viewtopic.php?topic=2321&forum=51
  • »21.07.23 - 07:13
    kriz
    Thanks @Templario I know he had a store page also, but i can not find it .. Maybe he will see this topic here soon :)
  • »21.07.23 - 08:14
    Doffo
    Posts: 508 from 2010/10/14
    I had a Mac Mini back about 10+ years ago in which I bought a generic 44pin to mSata adapter and a 32GB samsung mSata drive. Worked great when I had it. May as well go to that now to replace the aging hard drive that is in it now. :)
    YUUUP!
  • »21.07.23 - 12:11
    kriz
    Doffo: Excellent, i will give the mSata adapter a go :)
  • »21.07.23 - 17:43
