Problem with an external CD/DVD Drive
    Papiosaur
    Posts: 2612 from 2003/4/10
    Hello,
    i have bought an external CD/DVD Drive USB but Jalapeno see it as source (many entries for same drive in fact) but i can't choose any destination and impossible to write an ISO.
    It's possible to read MorphOS CD.
    Any idea ?
    Thanks ;-)
    [ Edité par Papiosaur 07.05.2021 - 22:00 ]
    [ Edité par Papiosaur 08.06.2021 - 14:32 ]
  • »07.05.21 - 17:58
    discreetfx
    Posts: 403 from 2003/7/26
    I had the same issue a few months ago and gave up.
    DiscreetFX
    Making your
    Digital Films
    More Effective!
  • »07.05.21 - 21:36
    NewSense
    Posts: 1618 from 2012/11/9
    Does anyone know what program(s)/libraries/device(s) controls the CD/DVD aspects within Ambient/MorphOS? :-?
    The MorphOS CD/DVD control of external devices (USB) for such "burning" functionality, and sometimes other intrinsic features (audio CDs), that should be able to be modified through settings/preferences, actually seems to be confined to an internal CD/DVD drive so these capabilities are incapable of being utilised currently, and ideally needs addressing . . . or at least that's how it seems to me.
  • »08.05.21 - 02:26
    NewSense
    Why do you have the same device, the Matsushita (Panasonic) UJ-835E listed 11 times in the settings of Jalapeno?
    Isn't once enough/sufficient, or is Jalapeno adding the drive automatically into settings? If not, then I'd delete the duplicate entries as they seem to be serving no purpose.
    If the GWA-4165B DVD/CDRW drive is on the internal IDE channel, then I would have thought it would write/read DVD-R/W and CD-R/W discs, but it seems to be set as Slave (IDE-2)!
    Having said that, you seem to still have the UJ-835E set as the default "burner" (Default Disc Copy Source) drive - were you aware of that too?
  • »08.05.21 - 03:54
    Papiosaur
    "Why do you have the same device, the Matsushita (Panasonic) UJ-835E listed 11 times in the settings of Jalapeno?"
    >I would like to know :-) It's the "bug"
    "Having said that, you seem to still have the UJ-835E set as the default "burner" (Default Disc Copy Source) drive - were you aware of that too?"
    >Yes, Jalapeno has put it automaticaly in "Source". About string "Default Disk Copy Source" for me it's the source not the "Destination" (Writer).
    "Isn't once enough/sufficient, or is Jalapeno adding the drive automatically into settings? If not, then I'd delete the duplicate entries as they seem to be serving no purpose."
    >Yes, Jalapeno add automaticaly it in the settings.
    "If the GWA-4165B DVD/CDRW drive is on the internal IDE channel, then I would have thought it would write/read DVD-R/W and CD-R/W discs, but it seems to be set as Slave (IDE-2)!"
    >I have 2 SATA Harddrive ("first way" reconnize as IDE) and the internal DVD Drive is on the "second way" IDE.
    [ Edité par Papiosaur 08.05.2021 - 08:24 ]
  • »08.05.21 - 04:24
    Posts: 1390 from 2010/1/6
    You may try direct programms of jalapeno in Mossys:Data/Jalapeno.
    MOSSYS:Data/Jalapeno/cdrecord -scanbus gives yo the device-indentifaication for your CD-Writer.
    Gives something like that:
    Bus 0 - usbscsi.device
    Bus 1 - sbp2.device
    Bus 2 - ide.device
    Bus 3 - 2nd.ide.device
    scsibus0:
    0,0,0 0) 'SONY ' 'CD-RW MPD-AP20U' '1.0a' Removable CD-ROM
    0,1,0 1) 'SONY ' 'MEMORYSTICK MPD ' '1.0a' Removable Disk
    0,2,0 2) *
    0,3,0 3) *
    0,4,0 4) *
    0,5,0 5) *
    0,6,0 6) *
    0,7,0 7) *
    scsibus2:
    2,0,0 200) 'ATA-HD' 'WDC WD5000AZRX-0' '' Disk
    2,1,0 201) 'ATA-HD' 'WDC WD5000AZRX-0' '' Disk
    2,2,0 202) *
    2,3,0 203) *
    2,4,0 204) *
    2,5,0 205) *
    2,6,0 206) *
    2,7,0 207) *
    scsibus3:
    3,0,0 300) 'PIONEER ' 'DVD-RW DVR-109 ' 'A912' Removable CD-ROM
    3,1,0 301) 'ATA-HD' 'SanDisk SDCFB-51' '' Disk
    3,2,0 302) *
    3,3,0 303) *
    3,4,0 304) *
    3,5,0 305) *
    3,6,0 306) *
    3,7,0 307) *
    First entry is a USB-CDRW. ( dev=0,0,0 )
    Now you may use cdrecord to burn something on that device. See cdrecord -help for otions.
    To make a ISO use mkisofs
  • »08.05.21 - 05:46
    Papiosaur
    Question : is it possible to boot MorphOCD via external drive and install MorphOS please ?
    I have tried to push Alt at startup, i see MorphOS CD and a usb logo under the icon, i select it then white screen...
    Thanks!
    [ Edité par Papiosaur 10.05.2021 - 21:44 ]
  • »10.05.21 - 17:43
    No, Mac won't recognize it in Boot-Menue, because its on the USB-port, which is'nt supported (officially) to boot.
    Mac can (official) only boot from SATA, IDE, FIREWIRE or Network.
    But it can be possible by calling USB-port directly in OF (like booting from as stick). I'm not sure, whether CD-filesystem is also recognized if CD-Drive is on USB and not on IDE-port......
    Pegasos: Not possible - USB (filesystem on USB) not supported.
    Efika: Should work(?), but I never got it working. Maybe a problem with my USB-CD-Drive.
    Others: Don't know!
    [ Editiert durch Amigaharry2 08.06.2021 - 20:11 ]
  • »08.06.21 - 16:10
    I'm not sure if FireWire supports CD too! I know it works for harddisks.
    Please serach about that, before you buy a FW-CD-Drive.
    The best way to boot ist from internal CD or HD. Or, if it's not a too old Mac, from USB-stick (only direktly from OF-console)
  • »09.06.21 - 04:20
    Yes, tested it now - works on G4-PB. If your Mac creates the UD-Device during runtime it's easy. You can check it in OF with command dev-alias
    Connect CD-Drive to USB, then turn on or reboot and goto OF-console.
    A device named ud should be shown. If it's ok, content of CD can be shown with dir ud:,\
    There is no way to boot automaticaly - you have to call propper boot.img for your Mac manually.
    Type
    boot ud:,\mac_ppc32\boot.img BD=CD0
    If you have a G5, then use mac_ppc64 instead of mac_ppc32.
    [ Editiert durch Amigaharry2 09.06.2021 - 13:37 ]
  • »09.06.21 - 09:35
    Posts: 611 from 2003/4/11
    Type
    Actually, with the very latest 3.15 HDimg written as raw data to a USB stick, you should be able to set the boot-device to ud:,\\:tbxi to boot directly from it.
    At least that is how I boot a MorphOS install image on my PBook5,8.
    Unfortunately, there are a few more pitfalls with USB, so results may vary. At least I'm pretty sure that you don't need to enter OF-console each time once you found a compatible USB stick and reconfigured the boot-device in OF.
    It also works on a PMacG5 and/or iMacG5 as the script included with the HDimg automatically selects the correct boot.img.
  • »09.06.21 - 09:41
    Very interessting! Tried that in the past and it won't work (but with older versions of MOS). So I did it with a boot-menue and created a bootable USB-stick (or USB-HD) and called boot.img there directly, which also works flawless.
    But useing the raw-data of the ISO and let do the Mac the rest, is the quickest way! I've to test this too......
  • »09.06.21 - 14:44
    Posts: 12558 from 2003/5/22
    > Very interessting!
    Indeed. While cyfm described this method a couple of times in the depths of the MorphZone forum, I think it deserves a more prominent place.
  • »09.06.21 - 18:41
