OpenBOR build 7142 ported by BeWorld
    Templario
    Posts: 549 from 2012/4/28
    Cool_amigaN escribió:
    Unfortunately Final Fight - Revival of Rage is incompatible: tested wit latest OpenBOR and after 1st Boss, game doesn't progress (also, end game selection from pause menu doesn't work), with version 6391 it produces heavy artifacts (plus some debug info all around the screen) while with old OpenBOR version it doesn't even load and quits immediately. Well, we can rule this out.
    @Templario
    Sounds like you have installed latest beta tinygl from Mark? If so, you need the fix which can be found here.
    [ Edited by Cool_amigaN 10.08.2022 - 23:08 ]
    Yes, I installed to see the new TinyGL.
  • »11.08.22 - 07:20
    Cool_amigaN
    Posts: 772 from 2011/11/30
    @Papi
    Does Evil Dead has music on you? I do get sound effects but no music while ingame.
    @all
    Unfortunately Avengers: United Battle Force seems to be incompatible. Crashes upon initial loading with latest version, quits even before loading with old version while ver. 6139 produces a lot of artifacts ingame. That's a pity though, 'cause the game is considered to be one of the very - very best around the OpenBOR community.
    Above tests are being conducted with latest SDL (SDL_2.24.0), in case that affects anything.
  • »22.08.22 - 06:06
    Cool_amigaN
    Yeap, I confirm video playback is way faster with latest SDL. Still, color has a red hue. So is this a SDL or OpenBor bug, BeWorld, what do you think?
    I also confirm I am now getting ingame music on Evil Dead Redux. Agreed, this game should also be uploaded to morphos storage, very high quality game indeed Papi :)
  • »23.08.22 - 05:34
    beworld
    Posts: 664 from 2010/2/10
    @Cool_amigaN, yeah in OpenGL mode, you are video in red "mode", not in SDL mode
    because video use YUV mode and need shaders for that :-)
    I think when new tinygl support "fragment shaders", I could rebuild OpenBOR with it.
    PowerMac G5 Quad 2.5, IMac G5 2.1, PowerBook G4 1.5, MacMini 1.5
    My MOS ports
  • »23.08.22 - 14:43
    Papiosaur
    Posts: 2408 from 2003/4/10
    @Cool_amigaN : Avengers: United Battle Force work here ;-)
    Game start with OpenBOR_6391 available in last archive, you must select SDL in Video option (Video backend).
    Seems work ok here...
    Upload soon...
  • »23.08.22 - 17:59
    Cool_amigaN
    @Papi
    Ah, didn't test it with SDL on ver. 6391, good catch. Nevertheless, pls include a readme, on how the user should be using it, imo.
    @BeWorld
    Noted. Hope Mark can finish it fast, so we can have a new perfected version of OpenBOR :)
    @all
    Knights and Dragons - The Endless Quest, created by Pierwolf is probably the best Dungeons & Dragons available on OpenBOR. Latest version (3.3), can be safely downloaded here (Chronochrash's link seems broken to me). This game is rather old but used to be incompatible with previous versions of OpenBOR, however now works perfectly with latest one (OpenGL too). Difficult game, you must use defense button when fighting 'cause your health gauge is minimum.
    Final Fight Apocalypse - 2nd Edition works fine too. Created by Mr. Q (Rhythm of Destruction, Art of Fighting, Double Dragon series), it's rather old and could be considered as a DLC under modern gaming language, since it's more or less of the same characters with same moves under different background set. It's fine for a spin but not as good as other options discussed in the thread.
    Final Fight and Cadillacs (ver. 2.0) is much more interesting while being a much newer mod too (2021). Though the game loads and plays fine in the beginning, after 2nd stage it starts to lose fps up to the point it crawls and becomes unplayable. This, on a G4@1.6Ghz, perhaps a thorough test under G5 would be useful imo.
    [ Edited by Cool_amigaN 24.08.2022 - 11:09 ]
  • »24.08.22 - 06:08
    Cool_amigaN
    @Papi
    Since you are at it, check and upload also Justice League Legacy. Together with Avengers: United Battle Force, these are the best two Super Heroes mods. JLL started developed around 2017 and latest update was just 6 months ago (think it's based on a previous effort of same dev. "Justice League United"), it's a very big game (about 380MB PAK file and requires 250-400MB free RAM on MorphOS, depending on the level), works perfectly with latest OpenBOR (OpenGL too) with operational ingame sidekicks too, which is a cool feature. It sports more than 60 characters, each with a special move, be sure not to miss it.
    [ Edited by Cool_amigaN 25.08.2022 - 16:13 ]
  • »25.08.22 - 11:10
    Cool_amigaN
    Some further testing for all of you to enjoy :)
    Splatterhouse Trilogy is an oldie but goldie horror mod that works perfectly (in case you liked Evil Dead, try this too).
    Asterix And Caesar'S Challenge is an also old mod which works perfectly (and it's the only Asterix themed mod too). A bit hard though, better if you have a friend playing together.
    Fighters History Revenge is an intermediate release (2016), again by the legendary developer Pierwolf and works perfectly. It's a typical beat 'em up without any particular strength. It's ok for a try but nothing close being as an unforgettable experience.
    Super Fightin' Spirit is a spin off from the famous Amiga game, remade as a brawler. Really colourful with smooth gameplay. Runs perfectly and sidekicks work too (up to 2). Another oldie but nostalgia hits hard on this one ;)
    GI Joe: Assault on Cobra Island (ver. 1.2) seems to quitting immediately after launch. Can someone else re-test pls?
    [ Edited by Cool_amigaN 29.08.2022 - 21:57 ]
  • »29.08.22 - 16:53
    Cool_amigaN
    Even further tests :)
    Beat Em Up Ultimate Alliance is a recent mod (2019). In some forums it's listed as beta in some others as complete. Works great though and can be downloaded here. It's an extremely good remix of various beat 'em ups and it's based on SOR2X (hence it's solid;)). Big pack (360MB HD) and requires a lot of free ram (approx 500MB, depending on the level).
    Btw, the rather old but famous Balance of Power also works great. Used to be one of the greatest brawlers on OpenBOR community but imo today shows a lot of its age. It's fine for nostalgic reasons but if you haven't played it, skip it, as there as better games around.
    Pestilaence has been released just a month ago. Works great. It has a horror theme as cross mix between Splatterhouse / Evil Dead with Postal / Resident Evil atmosphere. Don't really liked but if you appreciate the genre, be sure to play it.
    Street Fighter Taiwan, is also a very interesting remix with a background set of.. yeap, you guessed it, Taiwan :P It's small and compact and you can download it, here.
    TURRICAN vs TERMINATOR is another recent mod (2021) that works great too and deserves a home on morphos-storage imo. It's a crossover from our beloved Turri vs Terminator-like and similarly inspired enemies shoot 'em up. Be sure to give it a chance! You can download it,
    here :)
    X-Men Hunter for Mutants works too. It's an intermediate release (2016), has some interesting gameplay concepts but overall is rather weak and doesn't deserve a lot of attention. You can give it a go, here.
    Edit: Papio, check your PM. Also, when you have some free time, pls check GI Joe and let me know if it works for you.
    [ Edited by Cool_amigaN 01.09.2022 - 23:40 ]
  • »01.09.22 - 17:19
    Cool_amigaN
    Even more tests, even more games :)
    Power Rangers - Beats of Power: Special Edition is a relatively new game (Feb. 2017) and a true homage to the live action show. Smooth gameplay and cool soundtrack by the famous Merso-X OpenBOR developer. However, when on boss fight where you pick up your Zodd you should wait 30-45 secs for the fmv to finish on the background before you move. Other than that, the game is completely playable and enjoyable. Highly recommended.
    Golden Axe Remake - Special Edition is rather interesting, since it contains several original and remixed versions of the game (not the Amiga's though, which is a shame). Plays very nice.
    Golden Axe: The Curse of Death Adder has stylus graphics and nice sound effects along with several playable characters. Plus, it's compatible too.
    Golden Axe: Genesis is a rather moderate Golden Axe game. The Genesis refers to the Sega's console version. Not something memorable but if you are into the Golden Axe extravaganza , then this title is for you since it plays very well too.
  • »06.11.22 - 19:29
    Cool_amigaN
    Golden Axe Returns is a new high quality game created by ZVitor (Marvel Ultimate Alliances / DC Justice League) and was released just a month ago. Great character variation, original graphics, new gameplay features (weapon selection) and nice music remixes used. Finished it under co-op (takes around 1:30h) and plays awesome under latest OpenBOR port from BeWorld. Recommended.
  • »03.03.23 - 20:50
    Cool_amigaN
    New game: AvP (Capcom Arcade), from ZVitor, not to be confused by the 2015 SoR remix. Though it's labelled as beta, game can be completed (takes about 1 hour). On Hard mode it features extra characters. Great quality and fun, highly recommended and of course runs perfectly with our latest OpenBOR version. Can be downloaded from here. Enjoy :)
  • »07.07.23 - 14:18
    Cool_amigaN
    Happy to inform that Rocket Viper (from Volcanic modder) works ok (apart from 3 enemy models which have colour palette distortion but could go barely noticeable). However, above all, Rocket Viper 2 can be finished too. Be aware that RV2 was a heavy scripted and highly anticipated mod a decade back. Though it could be considered one of the best first gen. mod games, it was highly unstable even back then on a WinPC. In the occasion OpenBOR quits while loading an enemy set ingame, you could easily re-launch it and continue from the load game menu. It's highly enjoyable especially under co-op given that players can throw enemies to each other and perform tons of special moves. Unfortunately, Night Slashers X (both original and rebalanced version) seem incompatible, as OpenBOR quits after 2nd stage. I 've tried with different OpenBOR versions and options (SDL/OpenGL) but it's a no go. Let me know if anybody else can confirm it too.
  • »06.12.23 - 20:19
