amicraft / minetest
    Mabo
    Posts: 67 from 2010/5/3
    Hi Folks !
    Is there any chance that a minecraft clone will be ported to MorphOS ? Let me know if there is a similar one that I can play at present day.
    Ty ^^
  • »18.08.23 - 00:55
    BatteMan
    Posts: 294 from 2003/2/24
    We have Craft, by Yomgui (who ported Python and Blender to MorphOS, and also developed PyMUI, Gribouillis or the wonderful Firewire stack for MorphOS) : http://yellowblue.free.fr/yiki/doku.php/en:dev:craft:start
    Yomgui, tu nous manques ! #coeuraveclesdoigts
  • »18.08.23 - 08:39
    Blasterreal
    Posts: 41 from 2007/3/30
    Yomgui hasn't been around for a long time. Hope it's okay
  • »18.08.23 - 11:50
    Posts: 611 from 2003/4/11
    Yomgui is pretty much alive afaict, at least I talked to him earlier this year about some Python related things and the MorphOS port of Python he did way back.
    Unfortunately, he isn't really much into MorphOS nowaways and moved on to some other playgrounds - which is kind of a pity, as it is pretty sad not to have such a creative developer actively in our scene.
  • »18.08.23 - 14:19
    Mabo
    Is it possible to play Craft or is it in work in progress?
  • »18.08.23 - 15:40
    Papiosaur
    Posts: 2612 from 2003/4/10
    polluks has just uploaded it on Aminet:
    minetest
    Thanks polluks !
    It need Python preinstalled i think but i don't know how to launch it for the moment.
    [EDIT]I try many things but it does'nt launch, i have this error message:
    RuntimeError: Bad magic number in .pyc file :(
  • »19.08.23 - 03:40
    Papiosaur schrieb:
    Thanks polluks !
    There is a magic number in the first four bytes of any compiled bytecode .pyc/.pyo file which needs to match the magic number required by the installed Python version ... It would be helpful if the related file could be identified, could obviously be part of the installed python and/or the additional code installed.
    It is possible that the Python version used does not match the requirements of the installed code. It could also be that it is "just" some corrupt byte code file.
  • »19.08.23 - 06:40
    Papiosaur
    @cyfm,
    thanks a lot for your answer!
    I've tested all files of the root with all version of Python available on the storage and tested executable too. but with no success...
    Maybe a file corrupt in fact...
    If someone win to start it or have another archive...
  • »19.08.23 - 06:58
    Mabo
    Tysm guys ^^
    Yes I don't know how to start it :| Im not familiar in pyton :(
    If someone can explain how to do that would be much appreciated :)
    Ty to @cyfm and @Papiosaur to give it a try ;)
  • »19.08.23 - 13:31
    Papiosaur
    i've found this syntax to AmigaImpact posted by Batteman 10 years ago, thanks Batteman! ;-)
    python2.5 -O main.pyo –r r.0.0.mcr -x 5 -z 5
    So you need to install Python 2.5 before, and i have realized a "cd partition:minetest/ before.
    Here a window 'Test' is open and i have "application is mediating"... (on Powerbook and G5)
    Maybe it work on a Mac mini ?
    I have tried with a stack but without success...
    Any ideas ?
  • »19.08.23 - 15:33
    Posts: 847 from 2007/10/23
    Maybe you need an older MorphOS/TinyGL...
  • »19.08.23 - 16:32
    Mabo
    Any ideas ?
    This one ? https://www.morphos-storage.net/?id=1532060
  • »19.08.23 - 17:06
    Papiosaur
    @polluks: Yes, i will try old, thanks ;-)
    @Mabo: yes this one ;-)
    [EDIT] Tried with TinyGL from MorphOS3.0.iso but without success...
    [EDIT2] Should work with TinyGL from MorphOS 3.1, i will install it this evening to test.
  • »19.08.23 - 17:15
    Mabo
    OK I downloaded that python versione, and now ? What I have to do cause i dont see any installer :/
  • »20.08.23 - 12:57
    Mabo
  • »20.08.23 - 12:58
    Mabo
    Papiosaur wrote:
    You must copy C drawer and LIBS drawer to SYS: (partition named "System" normally)
    Is that all ? Thank i go via shell.
  • »21.08.23 - 10:03
    Mabo
    Same issue on my MacMini G4 1.5
    08f78995f62b26ce90a986ea9b02c7db
    Python 2.5 was released on September 19th 2006
    The last edit on Yomgui mintest page is:
    en/dev/craft/start.txt · Dernière modification: 2011/12/01 04:41 par Yomgui
    According to this:
    https://en.wikipedia.org/wiki/MorphOS#Release_history_of_2.x/3.x_series
    He probably used MorphOS 2.x or maybe 1.x
    Reagards
    [ Edited by Mabo 22.08.2023 - 18:32 ]
  • »22.08.23 - 13:46
    ppc-grinch
    Posts: 46 from 2025/7/17
    Seeing as how no one else has brought this up yet, and this exactly fits the description of OP's request, and there is no separate thread for it, here it is!
    Classicube 1.3.7, a Minecraft clone written from scratch in C, fits the bill of what you are looking for. Ported to MorphOS by BeWorld, Classicube 1.3.7 requires SDL 2.32.10 and TinyGL.
    Somehow I found this thread by accident and thought that something like this was recently uploaded to morphos-storage.net. Turns out, it was!
    Mac Mini G4 1.5 Ghz, ATI Radeon 9200 64MB, 1GB RAM
  • »05.12.25 - 00:10
