Crashes of OWB
    Templario
    Posts: 561 from 2012/4/28
    I have several carashes with OWB 1.24 like this:
    16:20:37 10-feb-18
    68k Exception 4 <Illegal Instruction>
    Task 0x2c39ea68 <OWB>
    Dn[0] 10000000 00000010 2bd9a240 2bd9a340 2bd9a3a0 2bd9a380 00000000 00000068
    An[0] 200c5e28 200bc9f0 38c781d8 00000000 00000000 00000000 20001948 2c39fb44
    PC 00000006 SR 0000
    Why 68k exception?
    And when we have the 1.25 version?
  • »10.03.18 - 11:26
    Posts: 849 from 2007/10/23
    Try to find a specific URL to reproduce this hit and fill a bug report.
  • »16.03.18 - 04:29
    Templario
    It isn't a special URL, sometimes the problem comes with Yahoo others with other sites.
  • »19.03.18 - 20:31
    Posts: 1392 from 2010/1/6
    Delete complete OWB-installation and install new.
    If error occours further, check whether there are double libraries in libs: and MosSYS:libs. Maybe you have erroneos installed a 68K-pedant of a MOSSYS-Library in libs:
  • »20.03.18 - 06:00
    Doffo
    Posts: 508 from 2010/10/14
    Yahoo works over here. Went to some other sites and works good. As some suggested, maybe a reinstall will help. What hardware are you on now? Your Mac Mini or the G4 Laptop?
    YUUUP!
  • »27.03.18 - 12:07
