KingPin, a small mindgame
    Posts: 2581 from 2003/2/24
    This a small game based on an xmas present on of my nephews got (I played it a bit with his father don't think he will ever touch it.....).
    Gobbled together in a few hours, lacking GFX, much of a user interface and only comes with 2 trivial levels atm.
    KingPin.lha
  • »01.01.18 - 12:42
    defender
    Posts: 249 from 2011/4/24
    Hi Kronos,
    Happy New Year. Thank you for this little game.
    (needs a few more levels :-) )
  • »02.01.18 - 05:55
    When it hits something "1.0" worthy.
    Current games takes about 12sec to finish (of which 4 are Delay()s in the code).
  • »02.01.18 - 12:04
    Posts: 848 from 2007/10/23
    It also made a news message in AmigaNews.
    This will hopefully not the MorphOS highlight for 2018 ;-)
  • »02.01.18 - 16:45
    NewSense
    Posts: 1618 from 2012/11/9
    I don't see what there is to do, other than move the '1' on the left hand side down from above the '0' down onto that area and then there are no more moves possible - is that all there is to it, or am I missing something ............... like a life!! 8-D
    [ Edited by NewSense 03.01.2018 - 06:48 ]
  • »03.01.18 - 05:48
    @NewSense
    - there is never "just one thing to do" as possible moves always come in pairs
    - in the 1st level you have 4 possible start moves
    - possible moves are indicated with a small arrow when hovering the mouse over a field
    I'd suggest you try to find those 4 possible moves 1st, which should lead to an *facepalm" moment ;)
  • »03.01.18 - 10:02
    New archive:
    - Added 3 more level (all still pretty simple)
    - You can now skip a level
    - Undo added
    The undo function will form the base for an (brute force) autosolver, which in turn might be the base for a level generator.
    KingPin.lha
  • »04.01.18 - 10:34
