Open X-Com Not an Executable
    XDelusion
    Posts: 602 from 2010/10/27
    I downloaded Open X-Com today to test out on my Efika.
    It claims it is not an executable. So I downloaded it again. Got the same message.
    [ Edited by XDelusion 12.07.2013 - 21:18 ]
  • »12.07.13 - 23:09
    Posts: 12499 from 2003/5/22
    I had no such problem on my Mac mini. Is the 'executable' bit set for the file?
  • »13.07.13 - 05:21
    Derringer
    Posts: 103 from 2008/8/4
    On PB no problem to run.
    However it chrashing at resolution change. To change resolution just don't touch anything, step in the options, and quit the game. Then edit the cfg file and the second resolution (not base) set it to for example 800*600. (or anything to like)
    [ Edited by Derringer 13.07.2013 - 11:21 ]
    MorphOS PowerBook G4 1,67GHz, 2GB Ram, 250GBHdd, ATI 9700/128MB
    Morphos G5 2,7GHz, 8GB Ram, 500GB Hdd, ATi Passive cooled 9800 PRO/128MB
  • »13.07.13 - 07:20
    XDelusion
    Yes, it was set as executable. I tried running it both from the icon as well as command line.
    I downloaded it twice, so I'm not sure what's up.
  • »13.07.13 - 10:45
    stefkos
    Posts: 96 from 2004/2/4
    I didnt check game on other processors then G4. Will try to launch app on Efika ASAP.
  • »13.07.13 - 12:52
    XDelusion
    Thanks!
  • »13.07.13 - 17:44
    Nitro
    Posts: 106 from 2003/8/24
    I had the same on thing on my Efika
  • »15.07.13 - 17:12
    stefkos
    ATM I have problem to get my efika here. Maybe someone can compile this game? I can send sources.
  • »16.07.13 - 03:59
    XDelusion
    Where is the guide again on how to compile under MorphOS? I need to learn how to do this anyhow?
    Stekfos, I got your PM, but do not know your e-mail. Unless it's at home with the X-Com readme. :)
    Anyhow, you can contact me at advertandentice AT Gmail DOT com.
    Thanks!
  • »16.07.13 - 19:07
    > Stekfos, I [...] do not know your e-mail. Unless it's at home with the X-Com readme. :)
    Indeed it is, in the bottom line at that. And there's another one:
    http://www.tbs-software.com/stefkos/about.html
  • »16.07.13 - 20:18
