G5 E-UAE wont run adf as 1200/500 after installing rezz scri
    Posts: 1915 from 2003/10/19
    I have a strange issue I cant seem to figure out. I have moved over the files from the bonus drawer in fabs e-uae and get the new context menu items to run in A500 and run in A1200 with E-uae but when I select one the system does nothing at all. I have the rexx libs in sys:libs like I should as well. This works fine on my powerbook, but not on my G5?? Am I missing something that needs to be done?
    All the roms and worbench files are also in the correct places.
  • »09.03.17 - 14:24
    Posts: 2794 from 2006/3/21
    Probably a dumb response, but did you copy the proper Arexx library to the G5 (or is that no longer necessary? It has been so long since I set up a new MorphOS system, I can't remember if this step is still required, and seem to remember some discussion that a solution which would eliminate the need to copy the Arexx library from any AmigaOS3.1 to 3.9 installation media to a new MorphOS system).
    I think I am loosing touch with the latest developments within MorphOS, as I only skim through these forums for info and don't spend much time putting any of it into practice, unless I run into a problem that requires more effort to resolve.
    [ Edited by amigadave 09.03.2017 - 10:05 ]
  • »09.03.17 - 19:03
    Posts: 12085 from 2003/5/22
    I think he did. At least that's what he wrote.
    It is.
    > I [...] seem to remember some discussion that a solution which would
    If you mean this, it doesn't work with existing ARexx scripts. And the ARexx library based on Regina Rexx didn't come to fruition.
  • »09.03.17 - 21:08
    Strange, all this is done and verified. I have done it on my Powerbook with the same settings and its fine, but nothing works on my G5. Well the Run in UAE works, but it only launches the 3.1 install and will not run any apps you click and select run in UAE. The other two still do nothing.
  • »10.03.17 - 04:29
    Posts: 2033 from 2003/2/24
    Or maybe remembering RXCmd, which allows you to send ARexx commands to programs out-of-the-box without the mentioned library, but it doesn't work for full scripts.
  • »10.03.17 - 06:17
